compustar outputs not going to ground
jamball
Member - Posts: 6
Posted: December 18, 2007 at 8:45 PM / IP Logged
I have a Compustar Remote starter/alarm and the (-) outputs for Lights, ignition, starter, accessary will not go to ground when the starter is activated. The status output does work and it is from the same plug as the others. Does anyone know what might be causing the rest of the outputs not to go to ground?
evileagletalon
Copper - Posts: 65
Posted: December 18, 2007 at 10:53 PM / IP Logged
bad harness, defective unit, burned outputs, it can be many things. The best thing you should do is return it to the Authorized Dealer that you bought it from.
peterubers
Silver - Posts: 706
Posted: December 18, 2007 at 10:54 PM / IP Logged
i'm assuming you've metered these outputs and that the harness seems intact --
all this being said, sounds like a bad brain -- blown transistors
The search function is your friend.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
