2008 ford escape immobilizer wiring
bbtaco
Copper - Posts: 119
Posted: December 28, 2007 at 4:26 PM / IP Logged
What are the colors of the TX, RX, power and ground wires going to the four pin connector under the ignition switch? Is it possible to grab these at the wire loom under the lower front part of the dash underneath the steering column?
KarTuneMan
Platinum - Posts: 7,056
Posted: January 05, 2008 at 9:52 AM / IP Logged
Should be PURPLE / gray RX. Yellow/orange TX. @ the transponder module under the column.
OR RED / black RX, BROWN / orange TX
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
