1998 mazda 626 remote start
huicca
Posted: December 30, 2007 at 3:27 PM / IP Logged
Everything else works fine, but it dosent start... Acc goes on, Ign goes on, and then nothing?
All wiring diagrams shows that there are 4 wires (and 2 +12v wires) in ignition harness:
          Start Green
          Ignition              BLACK/ White
          2nd Ignition          BLACK/ Red
          Accessory             Blue
But I have BLACK/ Blue, BLACK/ White, BLACK/ Red and Blue. The blue is onlyone that gives 12v at ign and start position, and I wont find the starter wire. First time I measured the wires, BLACK/ Blue was 12v at start(I think) but now it is grounded all the time.
The car starts normally with key.
The alarm/remote starter is Magicar 3000, and everything else works.
...and sorry about my bad english...
pss5075104
Copper - Posts: 144
Posted: December 30, 2007 at 3:34 PM / IP Logged
your started wire should show 12v only with key in start position, if you think you have found it but are still not sure cut it in 2, if it is the starter wire when you try to crank th car with the key it will not do anything.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 30, 2007 at 3:55 PM / IP Logged
12 VOLTS Black Ignition harness   +
 IGNITION BLACK/ white Ignition harness   +
 ACCESSORY BLACK/ red Ignition harness   +
 STARTER BLACK / YELLOW Ignition harness   +
This is what wiremagic lists.  Astro lists what you have wow what a difference
huicca
Posted: December 30, 2007 at 4:07 PM / IP Logged
OK... Ifind this picture at Mazda workshop manual.
If I understand it right, I should have two wires with +12v at start position, but I cant find any.
1998 mazda 626 remote start - Last Post -- posted image.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
