dual voice coil
n2audio
Copper - Posts: 95
Posted: January 10, 2008 at 8:52 PM / IP Logged
rj_archer wrote:
ok so how can i wire mine up so its 4 ohms ? i seen that i can only get 2 or 8 ohms wen wired up is that tru
if it's a dual 4 ohm voice coil then yes, it can be wired for 2 or 8 ohms.
99% of the time a higher power sub like that is going to be run at 2 ohms instead of 8.
There are pleny of mono amps that will produce the type of power you're looking for into 2 ohms.
the wiring would be done like this
dual voice coil - Page 2 -- posted image.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
