need wiring for 2007 hyundai tucson
geotexz71
Copper - Posts: 65
Posted: January 09, 2008 at 6:15 PM / IP Logged
Been awhile! Searched the wiring diagrams and forum and didn't find anything on a 2007 Hyundai Tucson. Will be moving a Viper 791xv (alarm and starter) from owner's previous vehicle into the Tucson. Could use some help in locating the needed wiring for a time efficient install! Will be using an XK05 bypass too. TIA!!!
Twelvoltz
Platinum - Posts: 2,384
Posted: January 09, 2008 at 6:53 PM / IP Logged
Audiovox Lists:
          #511971: 2007 HYUNDAI TUCSON 4DR SUV WITH 2.0L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED          (+)          RADIO HARNESS
     Accesory          YELLOW          (+)          RADIO HARNESS
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          PINK          (+)          RADIO HARNESS
     Dimmer          GRAY          (-)          RADIO HARNESS
     Power Antenna          GRAY/ORANGE          (+)          RADIO HARNESS
     Amp Turn On          GREEN/ ORANGE          (+)          RADIO HARNESS
     LF Speaker (+)          WHITE
     LF Speaker (-)          BROWN
     RF Speaker (+)          RED
     RF Speaker (-)          BLUE
     LR Speaker (+)          YELLOW
     LR Speaker (-)          BLACK
     RR Speaker (+)          ORANGE
     RR Speaker (-)          BLUE
     Amp Location          IN DRIVER SIDE CARGO AREA UNDER FLOOR
     Steering Cntrls          NO
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          ORANGE          (+)          IGNITION SWITCH HARNESS
     Starter 1          PINK          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          YELLOW          (-)          AT VEHICLE FUSEBOX BEHIND DRIVERS SIDE OF DASH
               WHITE PLUG
     Domelight Super          YELLOW          (-)          AT VEHICLE FUSEBOX BEHIND DRIVERS SIDE OF DASH
               WHITE PLUG
     Trunk Trigger          GREEN/ BLACK          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Alarm Disarm          BROWN          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Alarm Arm          YELLOW          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Parking Lights          BLUE/BLACK          (-)          IGNITION SWITCH HARNESS
     Convenience
     Please select another category
     Remote Start
     Accessory 1          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 2          YELLOW          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Speed Sense          GRAY/ORANGE          (AC)          IN PLUG UNDER DRIVERS SIDE DASH
     Brake Lights          WHITE          (+)          AT SWITCH ABOVE PEDAL
     Reverse Lights          BROWN          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Modules
     WIRE          LOCATION
     Doorlocks/Windows
     Power Unlock          YELLOW          (-)          AT DOORLOCK CONTROL MODULE TO RIGHT SIDE OF STEERING COLUMN
     PowerLock          YELLOW/ORANGE          (-)          AT DOORLOCK CONTROL MODULE TO RIGHT SIDE OF STEERING COLUMN
     LF Window Up          BROWN          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     LF Window Dn          ORANGE          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     RF Window Up          GRAY          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     RF Window Dn          GREEN          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     LR Window Up          BLUE          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     LR Window Dn          PINK          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     RR Window Up          BROWN          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     RR Window Dn          WHITE          (REV)          AT MASTER WINDOW SWITCH HARNESS IN DRIVERS DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
If you are in the US and the car was made for the US market you do not need a bypass module.
geotexz71
Copper - Posts: 65
Posted: January 09, 2008 at 9:03 PM / IP Logged
THANK YOU!!!
You say no bypass module? Are you certain? The Tucson was made for the US market, but does seem to have the RF key. At least, I had the owner check with Hyundai Parts and a VIN lookup and he told me the parts guy told him it needed "a special key" and it was spendy!!! I assumed then it had the RF loop indicated on your wiring info. Appreciate the help!
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
