2002 suzuki xl7
Kcautosound
Member - Posts: 33
Posted: January 18, 2008 at 3:34 AM / IP Logged
Hey guys I'm needing a detailed wire info for a remote start on this vehicle. Code Alarm tech sheet has limited info on it and I have an hour drive to this guys house to install. Just want to have some backup info. Would prefer a directechs info if someone has it. My login no longer works with the new site.
Kcautosound
Member - Posts: 33
Posted: January 19, 2008 at 12:34 AM / IP Logged
anybody please? Would like to get this guy taken care of tomorrow? I can always figure it by myself but any tech help is always welcomed.
tedmond
Gold - Posts: 4,610
Posted: January 19, 2008 at 6:17 PM / IP Logged
WIRECOLORPOLARITYLOCATION 2002 suzuki xl7 -- posted image.
2002 suzuki xl7 -- posted image.Battery WHITE/ YELLOW (+) IN HARNESS FROM IGNITION SWITCH
2002 suzuki xl7 -- posted image.Ignition 1 BLACK/ WHITE (+) IN HARNESS FROM IGNITION SWITCH
2002 suzuki xl7 -- posted image.Accessory 1 YELLOW/BLACK (+) IN HARNESS FROM IGNITION SWITCH
2002 suzuki xl7 -- posted image.Starter 1 BLACK / YELLOW (+) IN HARNESS FROM IGNITION SWITCH
2002 suzuki xl7 -- posted image.Tachometer BROWN / SIL.DOT
2002 suzuki xl7 -- posted image.Parking Lights RED / YELLOW/SIL.D (+) 18 PIN WHT PLUG BELLOW FUSE PANEL
2002 suzuki xl7 -- posted image.Brake Lights GREEN / WHITE
2002 suzuki xl7 -- posted image.All Door Trigger BLACK/ RED (-) 18 PIN WHT PLUG BELLOW FUSE PANEL
2002 suzuki xl7 -- posted image.Trunk Trigger WITH DOORTRIG
2002 suzuki xl7 -- posted image.Power Unlock PINK/GREEN (-) STEERING COLUMN. BOTH WIRES FOUND ON 16
2002 suzuki xl7 -- posted image.PowerLock PINK (-) DOORLOCK MODUAL LOCATED ON R/SIDE OF
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
