1993 cadillac deville, remote start
anthonylecuona
Copper - Posts: 51
Posted: January 26, 2008 at 2:24 PM / IP Logged
no matter what I do i cant get the Car to crank try to bypass the vats with resistors even matched them to the key exactly. same resistence but the damned think wont crank. if yo put the key in the ignition and start the car then push the remote start it grinds the starter. any help tips tricks on this vehicle and vats bypassing would be great. as always thanks
In case of snow drive backwards, instant front wheel drive, then again who needs it when you drive a Scoobie
Chris Luongo
Platinum - Posts: 3,746
Posted: January 26, 2008 at 3:03 PM / IP Logged
If the remote starter doesn't work properly with the key sitting in the ignition, then it isn't yet installed properly.
It would be easier and less confusing to troubleshoot all other errors first, leaving the VATS bypass for last.
After the unit works correctly with the key in the ignition, then proceed to VATS.
anthonylecuona
Copper - Posts: 51
Posted: January 26, 2008 at 6:43 PM / IP Logged
it does work fine but the starter doesnt crank unless the key is in the run position and it doesnt have a brake interlock on it, just cant figure the vats issues out.
anthonylecuona
Copper - Posts: 51
Posted: January 26, 2008 at 6:50 PM / IP Logged
another thing dei says the unlock wire is black in the driver kick panel it doesnt exsist but the light blue is there and i have probed every wire in the kick for voltage on the meter at unlock
aaronrs4
Member - Posts: 27
Posted: January 26, 2008 at 10:49 PM / IP Logged
Lock / Unlock wires should be either Lt.Blue and White of LtBlue and Black right at the relay pack. As far as you issues with the starter itself, something isn't hooked up correctly. If you start the car with the key and press the remote start, it shouldn't grind the starter, because it should sense that the car is on. What kind of system are you installing? Did you connect and learn the Tach signal?
Install it like everyone will see EVERY part of it.
anthonylecuona
Copper - Posts: 51
Posted: January 26, 2008 at 11:36 PM / IP Logged
using a avital avistart 4100
Chris Luongo
Posted: January 27, 2008 at 10:20 AM / IP Logged
Issue 1, remote start: Maybe it's the word "grind" that's confusing us.
With the key in the ignition, when you operate the remote start, are you saying that it works perfectly, or that it cranks the starter too much?
Where are you getting the VATS wires in the car, and how are you interfacing with them? Are you using just a resistor to bypass the system permanently, or a resistor and a relay as shown in the install manual?
The correct VATS wires should be two thin (so thin they're hard to work with) white wires, inside a plastic sleeve that could be orange or black. (Note that airbag wires are yellow.....it's defininitely NOT yellow.)
2. Doorlock issue. I've never worked on an '89-93 de Ville, but I've heard other installers on these forums find the same thing you did. I guess the car has a LOT of black wires to test!
Some of them said that they just give up and run the wire into the driver's door and get it at the switch.
Or, as aaronrs4 said, the factory relays are probably high up in the passenger's kick panel, in the fuse box. Operate the doorlocks, listen for the relays clicking, and go there and see what you can find.
anthonylecuona
Copper - Posts: 51
Posted: February 11, 2008 at 11:01 PM / IP Logged
got the vats to work but still cant get the door lock wires to work lock unlock that is.with the remote start tried a few things and they dont work but it is very tight to get in the door jam cant fit much through there.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
