vauxhaal vectrs alarm info needed
sparkyboy
Member - Posts: 15
Posted: February 04, 2008 at 4:43 PM / IP Logged
Hi folks
Can anyone supply the wiring details for a uk Vauxhall vectra 2002
Security and audio would be very helpfull
Cheers
OOOHH wheres that smoke coming from
kola7126
Copper - Posts: 93
Posted: February 07, 2008 at 5:17 PM / IP Logged
SPECIFIC VEHICLE ALARM FITTING INSTRUCTIONS REV. 00
www.cobra.it
PETROL
MAKE OPEL MOD. VECTRA YEAR 04 fi DIESEL
ALARM/SIREN Position the compact alarms and the sirens under the battery bracket, as
POSITION aleternative: in the passenger’s side engine compartment. Pass the cables using
the rubber fairlead located in the bulkhead that divides the engine compartment
and the passenger’s compartment, near the battery.
CENTRAL UNIT POSITION Position the modular systems and the modules under the dashboard, driver’s side.
POWER SUPPLY +30: connect to a positive general supply wiring directly in the fuse box.
-31: connect to a ground terminal, under, on the left of the dashboard, driver’s
side.
IGNITION WIRE +15/54: connect to the 0,5 mm2 BLACK wire, at the position nr.11, in the grey
connector, in the fuse box under the driver’s side dashboard.
DIRECTION INDICATORS Connect to the wires: BLACK/ WHITE at the position nr.3 (ant. left),
BLACK/ WHITE at the position nr.4 (lat. left), BLACK/ GREEN at the position nr.2
(ant. right), BLACK/ GREEN (lat.right) at the position nr.9 located in the 50 way
green connector, in the central near the battery, in the engine compartment;
BLACK/ WHITE at the position nr.8 (post. left), BLACK/ GREEN (post.right) at the
position nr.9, in the 33 way blue connector, in the central placed in the driver’s
side boot. Separate the lines with 1N5406 diodes.
ELECTRIC WINDOWS Negative control signal
The closing is obtained timing the RED / YELLOW wire, at the position nr. 25, in the
46 way black connector, coming out of the central inside the driver’s side door. For
3100 and 3900 series antithefts install a timed relay Art.1055 and connect to the
brown wire of the antitheft.
CENTRAL DOORS LOCKING Negative controls
Connect both the OPEN and CLOSE wires (violet and orange) of the antitheft to
the RED / BLACK wire located in the wiring harness coming out of the original pushbutton
of the central locking placed in the driver’s side door. Insert a 470 Ohm
resistance in serie to the ORANGE wire of the antitheft.
IMMOBILISATION POINT Fuel pump
Cut the RED / BLUE wire, at the position nr. 3, in the 33 way black connector - C1
section - located in the central inside the driver’s side boot.
STARTER +50: Cut the 2,5 mm2 BLACK/ RED wire located in the wiring harness coming out
of the 6 way black connector, in the front part of the fuse box.
BONNET SWITCH Install an additional switch on the headlamp support plate, driver’s side.
DOORS SWITCH Connect to the BROWN wire, at the position nr. 60, in the connector placed behind
the left lateral bulkhead, driver’s side.
BOOT SWITCH Connect to the BLACK wire, at the position nr.6, in the 33 way grey connector - A1
section - in the central placed in the driver’s side boot.
Note: This information is not binding, therefore it must be considered only an example for installation purposes that must be executed opvec04gbb.doc
as per the instructions given on the product installation manual.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
