amplifier blowing fuses and powering off
thegage
Member - Posts: 27
Posted: February 15, 2008 at 3:55 PM / IP Logged
Hey all, Im new to 12volt and hoping to resolve my problem.
My problem is that when im listening to music the amp will just turn off. From ether one of two reasons, a fuse on the amplifier is blown, or the amp will simply turn off, and turn on again when I start the car next.(also I have noticed the amp gets hot enough to fry an egg on sometimes)
I have the subs wired at 1 Ohm, and the amp set to the lowest hertz, and on low pass filter.
Anyone have any idea what could be going on?
Here are the details:
     I have a 1996 Toyota Camry Collectors edition
     two 12" Diamond Audio D1's.
http://www.diamondaudio.com/content/view/140/157/
     Rockford P550.2 Amp
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6&family_id=20&item_id=106463&locale=en_US
     2006 Model Kenwood Deck
     And 4 Gauge power and ground wire.
Thanks A Ton,
Gage
chris27
Member - Posts: 41
Posted: February 15, 2008 at 4:04 PM / IP Logged
you can't run that amp at a 1 ohm load.  That is a 2 channel and can be ran at 4 ohm bridged, 2 ohm stereo, or 4 ohm stereo.  With running it at a 1 ohm load you are causing the amp to go into protection.
thegage
Member - Posts: 27
Posted: February 15, 2008 at 4:08 PM / IP Logged
What wiring method do you recommend?
tezjet
Member - Posts: 27
Posted: February 15, 2008 at 4:14 PM / IP Logged
If you have it setup for a 1 ohm at the moment then I am guessing you have dual 4 ohm coils in which case your gonna run it like
amplifier blowing fuses and powering off -- posted image.
~Steve
thegage
Member - Posts: 27
Posted: February 15, 2008 at 4:24 PM / IP Logged
I didn't personally do the wiring, I had a friend do it. So im not exactly sure what he did to even wire it at 1Ohm.(and yes the subs are 4Ohm Dual Voice Coil)
So my next question is how can i wire it to be 550W x 1 @ 4-Ohms bridged RMS like it recommends on rockfords website?
tezjet
Member - Posts: 27
Posted: February 15, 2008 at 4:30 PM / IP Logged
Picture above!
thegage
Member - Posts: 27
Posted: February 15, 2008 at 4:36 PM / IP Logged
Ok cool, well thanks tezjet, and chris27 for your help. amplifier blowing fuses and powering off -- posted image.
chris27
Member - Posts: 41
Posted: February 15, 2008 at 6:07 PM / IP Logged
no problem
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
