2000 ford windstar, remote start
kakojan69
Posted: February 16, 2008 at 11:12 AM / IP Logged
Hi there..
I want to install remote starter in 2000 Ford Windstar, the only problem I have is this van has 3 ignitions the remote starter that have only 2 ignitions, how can I install this unit, someone told me to use relay but I not sure how to wire it
Can anyone help me with it
tedmond
Gold - Posts: 4,610
Posted: February 16, 2008 at 12:17 PM / IP Logged
this is what i have listed off my wiring charts
2000 ford windstar, remote start -- posted image.Ignition 1 WHITE/ YELLOW (+) IGNITION SWITCH HARNESS
2000 ford windstar, remote start -- posted image.Ignition 2 VIOLET/ORANGE (+) IGNITION SWITCH HARNESS
2000 ford windstar, remote start -- posted image.Accessory 1 VIOLET/ORANGE (+) IGNITION SWITCH HARNESS
2000 ford windstar, remote start -- posted image.Accessory 2 YELLOW (+) IGNITION SWITCH HARNESS
2000 ford windstar, remote start -- posted image.Accessory 3 BLACK/ GREEN (+) IGNITION SWITCH HARNESS
test your wires, sometimes wiring charts are wrong.
to wire up an additional ignition with a relay, look on your unit and look for an optional (-) 250 - 500mA output for ignition or programmable output and wire it to a relay like so
85 - optional (-) output from unit
86 - constant 12v
87 - high current 12v fused @ 15 or 20 amps
30 - to second ignition wire on car.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
