i need an autostart as 1584sh userguide
ecs.1980
Posted: February 17, 2008 at 11:29 AM / IP Logged
ello there
I recently bought a used vehicle it came with an autostart AS-1584SH Command start I am not sure how to use it, I have a manual transmission 98 Honda CRV, I cant seem to find a user guide on website if someone could help me tha would be great
all the info on the box under the steering column is as follows:
Serial Number
209 433 374 151
Product # AS-1584SH
Date 9/11/2002
V. H1.2 S1.1
FCC ID: NAH 800R
CANADA:2678 102 309A
any help would be great
ecs.1980
swerks
Copper - Posts: 224
Posted: February 17, 2008 at 12:30 PM / IP Logged
go to autostart.ca and use the manual download link
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
ecs.1980
Posted: February 17, 2008 at 3:01 PM / IP Logged
I checked there it doesnt seem to work
ecs.1980
ecs.1980
Posted: February 17, 2008 at 3:02 PM / IP Logged
it would even help if someone could exp[lain to me how to use the command start
ecs.1980
jmroussel
Member - Posts: 42
Posted: February 20, 2008 at 10:37 AM / IP Logged
Hi ecs,
This is the way it works: when you are at your final destination, put the vehicle in neutral, release brake & clutch and pull E-brake on, you will hear 2 or 3 clics & pk-lights will flashs; turn the ign key off & out of ign switch, open driver door, get out & close door then press on start button on your remote. The vehicle engine will stop running & is in ready mode, you can start it as long as you do not open a door . That is a safety feather.
j-marc
moonliter
Copper - Posts: 322
Posted: February 20, 2008 at 8:29 PM / IP Logged
