amp mounting location
jmalbright
Member - Posts: 47
Posted: February 21, 2008 at 3:29 PM / IP Logged
Is it bad to mount an amp to the sub box?
I really don't have a great place in the trunk of my car other than the sub box to mount my amps.
aznboi3644
Gold - Posts: 2,600
Posted: February 21, 2008 at 3:43 PM / IP Logged
not at all if the box is sturdy and doesn't vibrate or flex
Platinum - Posts: 13,667
Posted: February 21, 2008 at 5:01 PM / IP Logged
A subwoofer enclosure that doesn't flex or vibrate.    Hmmmm.
audioman2007
Copper - Posts: 580
Posted: February 21, 2008 at 8:15 PM / IP Logged
When I have to mount an amp to the enclosure, I put foam behind the amp to give it a cushion and then I dont tighten the screws down tight.
hustlin247
Copper - Posts: 79
Posted: February 22, 2008 at 12:28 PM / IP Logged
Personally, I refuse to put extra holes in any enclosure ever. You want the tightest seal possible and screw holes compromise that.
'94 Ford Explorer / Kenwood KVT-815DVD / RF Power T1682C 6x8 (all doors) / RF Power T10001 / 12" Kicker L5 (x4) / Optima Yellow Top Battery
sparkie
Platinum - Posts: 2,061
Posted: February 22, 2008 at 1:19 PM / IP Logged
Use short screws so they don't go completely through the box wall. You should also make sure that the box can't slide around the trunk. This will prevent any undue stress on the wires connected to the amp. Make sure the amp isn't smothered against a rear seat to allow it to stay cool.
sparky
audioman2007
Copper - Posts: 580
Posted: February 23, 2008 at 8:40 AM / IP Logged
I agree with sparkie. On my fiance's amp I had to mount the amp to the back of her box so that she would have as much trunk space as possible. I simply put some foam under the amp then mounted it to the box using 3/4" screws. I did not tighten the screws all the way down that way the foam can do its part to dampen the amp from vibrating. Basically the screws are there just to keep the amp in place, but not tight against the box. Its worked perfectly.
