2008 mercury mariner
Welcome Guest :)
Memphisman
Copper -
Posted: February 22, 2008 at 7:30 AM / IP Logged
Does anybody know if the 2008 Mariner's wiring is the same as the 2007?
mikvot
Gold -
Posted: February 22, 2008 at 8:39 AM / IP Logged
Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
12 VOLTS | Blue/red | Ignition switch harness | + |
IGNITION | WHITE/ orange | Ignition switch harness | + |
ACCESSORY | Violet/green | Ignition switch harness | + |
STARTER | Blue/white | Ignition switch harness | + |
KEY SENSE | Blue/gray | At ignition switch harness | + |
TACH SIGNAL | Opposite from WHITE/ red | Any coil | AC |
| | Or Violet/brown at the PCM located on the firewall under the hood. This wire is in the plug closest to the passenger side. |
FUEL INJECTOR | Opposite from GREEN/ red | Any injector | AC |
LOCK | Blue/green | In driver's kickpanel | - |
UNLOCK | Yellow/violet | In driver's kickpanel | - |
DRIVER LOCK MOTOR | Gray/brown | In driver's kickpanel | REV POL |
DRIVER UNLOCK MOTOR | Blue/green | In driver's kickpanel | REV POL |
DOORPIN | Gray/violet | Fuse box (passenger side of center console) or driver's kick panel | + |
| | Gray/violet catches all doors, independent wires can also be used; GREEN/ violet, White, Yellow, Green... must diode isolate, see diagram. |
TRUNK PIN | Gray/orange | Fuse box (passenger side of center console) | - |
FACTORY DISARM | Violet/brown | Driver running board | - |
BRAKESWITCH | Gray/brown | At switch or in driver's kickpanel | + |
PARKLIGHTS | Violet/white | Fuse box (passenger side of center console) | + |
HAND BRAKE | Gray/blue | Fuse box (passenger side of center console) | - |
HORN | Brown | Steering column harness | - |
CLUTCH SWITCH | Gray/violet | Clutch switch | Type 1 |
VSS WIRE | Violet/orange | At PCM on firewall (in engine compartment) | AC |
Thursday, May 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
