pioneer cde6668 wire pin out?
jnuts247
Member - Posts: 31
Posted: March 14, 2008 at 5:05 PM / IP Logged
I Have An AVH-P7480DVD Unit I Am About To Install In A 06 Mark LT.. The Unit Was Pulled Out Of Another Car Recently But Very Quickly.. I Went To Install The Unit In The Truck And I See That On The Back Of The Unit Itself The Wire Clip (Pioneer Part#CDE6668) Is Missing Everything Except The Ill. And The Video/Audio Out Puts?? I Wanted To Know If Anyone Has A Picture Of The Back Of The Clip Or A Pin Out For The Clip, I Am Trying To Re Solder The Wires That Its Missing But I Don't Know Where They Go On The Clip?? The Only Reason I Ask Is Because This Truck Has To Be Done This Weekend, I Was Going To Order Another Clip But There Is No Where Around Me That I Can Get It Fast Enough... Thanks For The Help!!
Platinum - Posts: 13,677
Posted: March 14, 2008 at 7:39 PM / IP Logged
If nobody else has any help for you, the entire bottom row of the pins are the shields of the corresponding pin directly above that pin.  There will be 3 sets of audio outs and the rest of them will be either a video out and the set of AV inputs.  Hopefully somebody else will be able to take a pic for you.
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
