sub magnet facing out of box.
hookedonaudio
Member - Posts: 21
Posted: March 16, 2008 at 4:29 PM / IP Logged
It seems that it sounds better when you face the magnets out of the box. Does anyone else do this, the speakers I have are both free air, but with all four sub magnets facing out I cant fit them all in the trunk, so I have a pair firing down to the back floor board. Laugh if you will but I want big sound in a little car. so what are the pros and cons of facing sub magnets out of the box?
audiocableguy
Copper - Posts: 630
Posted: March 16, 2008 at 5:15 PM / IP Logged
did you flip phase when you mounted magnets out?
hookedonaudio
Member - Posts: 21
Posted: March 16, 2008 at 6:50 PM / IP Logged
I'm not quite sure what you mean by flipping phase, will this seriously affect the sound quality of the subs if this isn't done.
jeffchilcott
Platinum - Posts: 2,483
Posted: March 16, 2008 at 7:10 PM / IP Logged
If you dont know what phase is you more then likely have one set of subs working aginst each other.
With one set facing in the box and one firing out, one set needs to be wired backwards of the other set to keep them all pushing in the same direction.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
greenbroncoguy
Copper - Posts: 299
Posted: March 17, 2008 at 12:58 PM / IP Logged
You say they are "free air", but then you keep talking about facing them backwards in a box; which is it? Are they running in an Infinite baffle-type configuration or something?
-Matt
Clean Install
Silver - Posts: 446
Posted: March 17, 2008 at 5:01 PM / IP Logged
by inverting a sub...will not make them hit harder...
an like they are saying prior to this post... u must reverse the wiring on the inverted set...
If we learn from each success and
each failure, then we can improve ourselves
Flakman
Copper - Posts: 365
Posted: March 19, 2008 at 11:27 AM / IP Logged
The only possible advantage I see (besides asthetics) of having the sub magnet facing out would be to give you a little bit more volume inside the box. However, this will give you very little; AND, if you are hard up for space in a little vehicle anyway, having the sub with the magnet out will take up more space than if you had the magnet in and built the box to take up the space that the magnet was using outside of the box (if that makes sense).
If you were using 2 subs and turning one around made things sound better, the replies are correct, you had one of the subs wired backwards.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
sedate
Silver - Posts: 1,173
Posted: March 19, 2008 at 1:53 PM / IP Logged
I can't really imagine the situation where the airspace of the magnet assembly will impact the way a subwoofer system sounds to human ears.
But eitherway, inverting the subwoofer and swapping phase doesn't change anything about the woofer - save the aesthetics.
greenbroncoguy
Copper - Posts: 299
Posted: March 19, 2008 at 2:31 PM / IP Logged
Depends on the woofer in question; some of them have motor assemblies that displace approaching 0.5 cu. ft or more., and I'm fairly sure you can detect a change in box size that large (depending on overal box size)...
-Matt
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
