2008 Hyundai Sonata Alarm/Remote Start Wiring
Welcome Guest :)
mp19934
Member -
Posted: March 31, 2008 at 5:50 PM / IP Logged
Is there a wiring diagram available for 2008 Sonata GLS 2.4L Automatic or can someone verify same as 2007?
Thanks, Mike
KarTuneMan
Platinum -
Posted: March 31, 2008 at 9:12 PM / IP Logged
12 VOLTS | Pink | Ignition switch harness | + |
IGNITION | Blue | Ignition switch harness | + |
ACCESSORY | Orange | Ignition switch harness | + |
STARTER | Green | Ignition switch harness | + |
TACH SIGNAL | Use a fuel injector | | |
FUEL INJECTOR | Opposite of Orange or Black | At any fule injector on engine | AC |
LOCK | Pink/black | In 20-pin plug at ETACM | - |
| | The ETACM module is located in the center console behind the climate controls. |
UNLOCK | Yellow/black | In 20-pin plug at ETACM | - |
DOORPIN | Pink | In 24-pin plug at ETACM | - |
HOODPIN | Green | In 24-pin plug at ETACM | - |
TRUNK PIN | Lt.GREEN/ black | In 24-pin plug at ETACM | - |
TRUNK RELEASE | Red | Low in driver's kickpanel | + |
| | You can also use a WHITE (-) in the 20-pin plug at the ETACM module behind the climate controls in the center console. |
FACTORY ARM | Yellow | In 20-pin plug at ETACM | - |
FACTORY DISARM | Orange | In 20-pin plug at ETACM | - |
BRAKESWITCH | Green | At switch above brake pedal | + |
PARKLIGHTS | Pink | At light switch harness or ETACM | - |
HORN | White | At steering column | - |
| | Can alos be found at the ETACM module behind the climate controls in the center console on gray connector. |
Your tach can also be found behind the guage cluster. It's white.
Friday, April 26, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
