2001 lexus gs430 mark levingston
jmoreno
Member - Posts: 28
Posted: April 12, 2008 at 11:58 AM / IP Logged
Hey 12volt i need the wiring diagrams for the mark levingston in a 2001 lexus gs430. if anyone can spare it i would highly appreciate it thank you...
jorge moreno
jmoreno
Member - Posts: 28
Posted: April 12, 2008 at 7:18 PM / IP Logged
is there a converter for tha factory h/u made by mark levingston to bypass the factory amp to aftermarket amps and yet keep allcontrols such as volume? I spliced into the input signal wire from the hu to a loc to amps the signals work and i hear the music fine but i lost the control of the volume i have no control of it whatsoever.. any help would be appreciated
jorge moreno
snotdobbs
Copper - Posts: 148
Posted: April 12, 2008 at 9:38 PM / IP Logged
have you tried tagging the speaker wires after the amplifier for an adjustable level control
jmoreno
Member - Posts: 28
Posted: April 13, 2008 at 9:28 AM / IP Logged
yea bro ive tried b4 tapping into b4 the factory amp and after and still the same result..
jorge moreno
Platinum - Posts: 13,670
Posted: April 13, 2008 at 9:48 AM / IP Logged
You must have tapped the wrong wires after the amp.  If the speaker changes volume the converter will change volume.  You really need to verify that you have the actual speaker wires coming off of the amp.
jeffwhiteman
Copper - Posts: 124
Posted: April 13, 2008 at 2:05 PM / IP Logged
Lexus 2001 GS 430 4DR Sedan
WITH MARK LEVINSONW/O MARK LEVINSON
WITH MARK LEVINSON
W/O MARK LEVINSON RADIO HARNESS
Wire Function Color Note Fuse # Size Location
+12V DC Battery(Constant) Blue / YELLOW    Dome  10 Amp  Junction block on passenger side
Switched Accessory Gray  To CD changer also  Radio 2  15 Amp  Junction block on driver side
Ground  WHITE/ black
Power Antenna  WHITE/ red  BLACK/ white for antenna A; WHITE/ blue for antenna B.
Mute  YELLOW /GREEN (amplifier)  Telephone and CD player mutes are blue/orange, and navigation ECU mute is GREEN/ red, all from the amplifier.
Left Front +  Black  Line level output
Left Front -  Red  Line level output
Right Front +  White  Line level output
Right Front -  Green  Line level output
AMPLIFIER OUTPUTS
12V DC Battery Blue / YELLOW    Radio 1  30 Amp  Relay box 1 in engine room
Remote Turn On (input)  Pink/blue  Accessory wire
Left Front Mid +  Pink  Or blue/black going to navigation unit pin 1 & out at pin 2 as pink (if equipped).
Left Front Mid -  Violet  Or blue/red going to navigation unit pin 10 & out at pin 11 as violet (if equipped).
Right Front Mid +  Light green
Right Front Mid -  Blue
Left Rear Mid +  Black  Passes thru the telephone transceiver and speaker relay.
Left Rear Mid -  Yellow
Right Rear Mid +  Red
Right Rear Mid -  White
Subwoofer 1 +  Lt.GREEN/ black  Or blue/black
Subwoofer 1 -  Lt.GREEN/ red  Or blue/red
AT SPEAKERS
Subwoofer 1 +  Brown
Subwoofer 1 -  Lt.GREEN / WHITE
RADIO HARNESS
Ground  WHITE/ black
Mute  YELLOW /GREEN or blue/black (amp)  Telephone and CD player mutes are blue/orange, and navigation ECU mute is GREEN/ red, all from the amplifier.
Left Front -  White  Line level output
Right Front +  Red  Line level output
AMPLIFIER OUTPUTS
Left Front Tweeter +  Brown
Left Front Tweeter -  GREEN / WHITE
Right Front Tweeter +  Blue/black
Right Front Tweeter -  Blue/red
Center Channel +  Brown
Center Channel -  GREEN / WHITE
Subwoofer 1 +  Brown
Subwoofer 1 -  GREEN / WHITE
AT SPEAKERS
Left Front Tweeter +  Blue
Left Front Tweeter -  Light green
Right Front Tweeter +  Red
Right Front Tweeter -  White
jmoreno
Member - Posts: 28
Posted: April 13, 2008 at 9:36 PM / IP Logged
thanx for the wires bro i really appreciate it pretty new in the installation field been doin great till this lexus...
jorge moreno
jmoreno
Member - Posts: 28
Posted: April 13, 2008 at 9:40 PM / IP Logged
these are the wires i tapped to b4 the amp..
which would you tapp on to?
jorge moreno
jeffwhiteman
Copper - Posts: 124
Posted: April 15, 2008 at 8:43 AM / IP Logged
I dont know much about this particular system, but logicaly it sound to me like you have the right ones, line level out from the radio. It seems odd that it didnt work.
flobee4
Silver - Posts: 585
Posted: April 15, 2008 at 9:02 AM / IP Logged
Those wires you taped into are already line level, no need for a Line out converter.  Just cut a RCA wire and slpice into those wires again.  Maybe thats what went wrong. LOC bring speaker level down to line level, you are already at line level just need to convert wires to rca jack and plug into amp.
good luck, Frank
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
