amp, sub recommendations
davidh_r
Copper - Posts: 59
Posted: May 05, 2008 at 8:58 PM / IP Logged
Which amp(s) would work best on a pair of Alpine SWR-1042D subs at a 2 ohm load?
aznboi3644
Gold - Posts: 2,600
Posted: May 05, 2008 at 9:41 PM / IP Logged
whichever fits into your budget
What enclosure do you plan on using with these subs?? Please don't say sealed
davidh_r
Copper - Posts: 59
Posted: May 05, 2008 at 9:48 PM / IP Logged
They are going into a 07 Cobalt which means limited space. Recommendations on an enclosure?
aznboi3644
Gold - Posts: 2,600
Posted: May 05, 2008 at 9:57 PM / IP Logged
Type R's sound like dog crap in sealed boxes. If you have room for a 3 cu ft net ported enclosure than they will sound very good.
Alpine Guy
Platinum - Posts: 2,478
Posted: May 05, 2008 at 10:00 PM / IP Logged
You either need a single amp that can do 1000 watts rms at 1 or 4 ohm , or 2 500 watts rms amps that can do it at 2 ohms each.
I like to stick with one amp, if you want to stick with Alpine and can afford it, look at the PDX-1.1000
BUT, if you can return the subs and get 2 SWR-1022D's, than look at a MRP-M1000.
stevdart
Platinum - Posts: 5,816
Posted: May 05, 2008 at 10:04 PM / IP Logged
I would venture to say that you'd need a vented box with 2 cu ft net airspace and tuned to anywhere between 35 Hz and 30 Hz.  I'd stay away from anything higher than 35 Hz (too much loss of SQ) unless you're striving for only loudness.
But some of the others here might have a different perspective on this than I do.  My thoughts here are based on a software-generated result of the SWR-1041D...I don't know how much of a difference there is in the models.
davidh_r
Copper - Posts: 59
Posted: May 05, 2008 at 10:12 PM / IP Logged
I'd like to hear recommendations for a subwoofer setup.
I have a 07 Chevy Cobalt with a I have a Pioneer DEH-P600UB head unit (Cobalt’s have limited trunk space and I'm unsure of exact dimensions but we can use the entire trunk space).
I listen to rap and techno music.
I want a crisp big bass sound and i don't care what it sounds like outside my car. The system is for my enjoyment, not flashing it off to my neighbors.
I'm looking to spend $2000-2500.
Need any other qualifiers to make a recommendation?
jettagli03
Copper - Posts: 311
Posted: May 05, 2008 at 10:23 PM / IP Logged
I completely disagree that Type-R's sound like dog crap in sealed boxes.
I ran two 12" Type-R's in a "temporary" setup (working at best buy, got them cheap with the discount) each in a 1.2 cu ft fiberglass sealed enclosure, dynamated sedan with a clean 600w at 4 ohms to each woofer and they sounded pretty clean. Not amazing but pretty much on par, if not slightly better SQ, with most mainstream $200 subwoofers.
teenkertoy
Copper - Posts: 112
Posted: May 06, 2008 at 4:47 AM / IP Logged
On subs/amp/box alone? That seems really disproportional considering the price of your head unit and the alpine type-r's you are mentioning.
I'm really confused.
-Justin
Malcom: "This is the captain. We have a...little problem with our engine sequence, so we may experience some slight turbulence and then...explode."
Jayne: "We're gonna explode? I don't wanna explode.
davidh_r
Copper - Posts: 59
Posted: May 06, 2008 at 9:26 AM / IP Logged
-Justin
Thats a decent head unit. What would i gain by getting a more expensive one? Nothing from what i can tell.
My post with a $2000 price range was originally a separate topic because i wanted to avoid confusion with the Type Rs being part of this budget, but one of the moderators moved it into this topic.
The $2000 price range is not with consideration to the type Rs and was meant to be a seperate discussion.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
