what setup is louder than this one?
bumpinexploder
Copper - Posts: 265
Posted: June 05, 2008 at 7:08 PM / IP Logged
ok i have a dilema kinda i bought a big system and now i dont have any money for a HO alternator. so what i wanna do is sell my setup and buy a lower power setup but one that may be louder.
CURRENTLY i have 4 cvr 12s and a hifonics 2008D amp pushing 1300 RMS to the subs wired down to 2 ohm. i wanna sell it and buy about a true 1000 watt amp (probly kicker 1000.1) because with stock alternator and red top under the hood that should be ok.
solution maybe? the guy at my local shop builds insanly awesome boxes! i love his boxes, there so loud and efficient. sooo i was thinkin gettin like 3 10s, 2 12s, or just one 15 and i was wondering what sub would be the best spl wise? also im kinda on a budget.
i may get about 650 for everything so thats my budget. i can get the amp for 250 so that leaves roughly 400 for subs and box. his box cost around average 175-240. so 160- 225 on subs. i shop off ebay so if you have a sub in mind look on ebay please as thats where i shop no matter what everyone says!
please help me out with this as i want a good system but dont wanna pay for a HO alternator as of right now.
(hopefully the pics show up)
<a rel="nofollow" href=" http://tinypic.com" target="_blank"><img src=" https://i27.tinypic.com/2nukbkl.jpg" alt="Image and video hosting by TinyPic"></a>
Pioneer DEH-400UB
Kicker 150.2 mids/highs amp
MB Quart fsa 216 front stage
AudioPipe gd-6001 mono amp
AUDIOQUE SD 15S PREFAB BOX!
C&D Technologies Battery, 1500 CCA, 134 amp storage
149.5 DB's
aznboi3644
Gold - Posts: 2,600
Posted: June 05, 2008 at 7:22 PM / IP Logged
first off a new enclosure could be a lot better than the one you have now...why is it along the right side and not in the cargo area?? lol
bumpinexploder
Copper - Posts: 265
Posted: June 05, 2008 at 7:31 PM / IP Logged
lol yea its too wide. so i took out the seat. its 59 wide and cargo is 39 wide i bought everything together for 300 so it was a good deal and i didnt care that it didnt fit. but yea what would be some good options. i heard aboput the kicker cvr 18. any good? i have the space for the massive box. i have a 94 exploder. BOX SIZE IS NO PROBLEM. or ma audios 18? let me know. please.
Pioneer DEH-400UB
149.5 DB's
ferretvw
Copper - Posts: 188
Posted: June 05, 2008 at 9:00 PM / IP Logged
As someone who used to have an explorer I can tell you that your alt. will not take that load either, you have either a 95 or 105 amp alt if I remember correctly and that amp at 75% efficiency needs about 85 amps which leaves 10 to 20 for all other loads in the vehicle. You will have severe dimming issues and will probably burn out that alternator after a few weeks of running it that way (I had the kx 1200.1 on my stock alt and it went after a month and that was with the big 3)So I would still recommend looking at an alt or an amp that puts out closer to 500 or 600 watts.
--->Richard
2008 Scion xB
Pioneer AVIC-D3
RF 3Sixty.2 sound processor
Stock speakers (for now ;))
bumpinexploder
Copper - Posts: 265
Posted: June 05, 2008 at 9:18 PM / IP Logged
if i upgrade to the 130 alternator then that should be fine right? 85 for the kicker leaving 45 for everything else as i dont have ac so everything on should be ok. thanks for that input, that helps alot. but now back to the original q. what kind of subs should i run then? givin now that i will probly run between 500-700 watts.
Pioneer DEH-400UB
149.5 DB's
aznboi3644
Gold - Posts: 2,600
Posted: June 06, 2008 at 12:12 AM / IP Logged
130 amp will still not be enough...You should get the biggest you can afford...at idle even with a 130 amp alt the voltage will still dip into the battery levels
ferretvw
Copper - Posts: 188
Posted: June 06, 2008 at 8:53 AM / IP Logged
Azn is correct most of the time manufacturers only put about 10-15% extra into the alternators so that means your car probably needs about 75-80 amps. You really need to look in the 200 amp range for a true 1000 watt amp. If you do not want to upgrade then you should stick with a lower power amp. as for the subs I would probably stick with 2 12's they are easier to wire than 3 10's and move more air than 1 15".
--->Richard
2008 Scion xB
Pioneer AVIC-D3
bumpinexploder
Copper - Posts: 265
Posted: June 06, 2008 at 11:45 AM / IP Logged
ok i like the 2 12s idea. but on a true 500 rms amp what subs are like 250 rms each? also i was looking at the p3 RF i think and the 15 is 500 rms which would suite it pretty well. whatever i get i wanna hard very hard clean bass and i know you can do that with lowpower setups im just tryin to figureout wat setup. so is that RF a good choice then put like a infinity amp on them? infinitys are one of my toip choices in clean amps
Pioneer DEH-400UB
149.5 DB's
bumpinexploder
Copper - Posts: 265
Posted: June 06, 2008 at 12:10 PM / IP Logged
sorry for the double post but i have another question. i was looking at RE audio subs and there is a 10 i like but its  1000 RMS. if i put about 500 RMS to it will it be as loud as if i get a sub that is 500 RMS and push it fully? i hear its louder if you get a sub and push its full rms rather than get a big sub and small amp. just wondfering becuase i really wantthat re audio sub.
Pioneer DEH-400UB
149.5 DB's
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
