cs5601 window module, how to?
tbird2340
Copper - Posts: 363
Posted: June 10, 2008 at 10:17 PM / IP Logged
I have a 2005 Dodge Ram Quad Cab with a RS1704TW2 Remote Start unit.
I want to install a Crime Stopper CS-5601 Window control modules (2 windows down and up).
What I am wanting to do is have the windows go down with the AUX button press on my RS1704TW2 remote and have the windows go UP when I lock the doors with the lock button on my RS keyfob.
I'm hoping someone can help because the manual is very confusing to me.. Below are the directions for the 5601 and my window wiring.
Wiring CS-5601 Manual
2005 Dodge Ram Window
8 Position Connector Plug – Small Wires
1 - GRAY: Negative roll trigger for Circuit #1 and #2.
        Circuit #1 and #2 are controlled by LOOP 1 - USE ONLY ONE.
2 - GRAY/WHITE: Positive roll trigger for Circuit #1 and #2.
3 - BLACK: SYSTEM CHASSIS GROUND: This wire must be connected to chassis metal of vehicle.
4 - GREEN: (-) 300 milliamps Negative output though out operation of any 4 circuits
5 - YELLOW: (+) 300 milliamps Positive output through out operation of any 4 circuits
6 - BLUE: Negative roll trigger for Circuit #3 and #4.
        Circuit #3 and #4 are controlled by LOOP 2 - USE ONLY ONE.
7 - BLUE/RED: Positive roll trigger for Circuit #3 and #4.
8 - PINK: Connect to an ignition wire that shows +12 Volts when the key in both “On” and “Start” positions.
     This wire prevents the module from activating the windows while driving the vehicle.
2 JUMPER LOOPS
LOOP 1: Circuit #1 and #2
CUT: Constant or Latched (starter kill), Trigger for window circuit #1 and #2.
CONNECTED: Momentary Pulse (2 channel), Trigger for window circuit #1 and #2.
LOOP 2: Circuit #3 and #4
CUT: Constant or Latched (starter kill), Trigger for window circuit #3 and #4.
CONNECTED: Momentary Pulse (2 channel), Trigger for window circuit #3 and #4.
9 Position Connector Plug – Large Wires
1 - RED WIRE: (+) 12 Volt Power Source (30 amp fuse) Connect to +12 Volt source with supplied fuse & holder. Recommended location for this connection is at a main power distribution terminal or the vehicle battery positive terminal.
2 - BLACK WIRE: (+) Switch side of window circuit #1. Normally Closed in reference to “BLACK” wire.
     Circuit #1
3 - BLACK/ WHITE WIRE: (+)12 volt output to motor side of window circuit #1.
4 - GRAY WIRE: Switch side of window circuit #2. Normally Closed in reference to “GRAY/WIRE” wire.
     Circuit #2
5 - GRAY/WHITE WIRE: (+)12 volt output to motor side of window circuit #2.
6 - BROWN: Switch side of window circuit #3. Normally Closed in reference to “BROWN / WIRE” wire.
     Circuit #3
7 - BROWN / WHITE: (+)12 volt output to motor side of window circuit #3
8 - BLUE WIRE: Switch side of window circuit #4. Normally Closed in reference to “BLUE/WIRE” wire.
     Circuit #4
9 - BLUE/WHITE WIRE: (+)12 volt output to motor side of window circuit #4
Thanks so much.
mikvot
Gold - Posts: 1,043
Posted: June 11, 2008 at 8:52 PM / IP Logged
What exactly are you having probs with.... I can walk you through the whole install, but would hate to write up the whole thing if you only have a few specific questions. I have used that window mod, so I am familiar with it. Just let me know if you need a full walkthrough, and I will do it....it might take a day or so for me to get back to you.
tbird2340
Copper - Posts: 363
Posted: June 11, 2008 at 9:40 PM / IP Logged
Well, the whole thing.. I just don't understand the directions.. That would be GREAT if you would do a full walkthrough. I would greatly appreciate it..
I've done around 30 remote starters so I know I'm capable.. I just don't understand the directions at all.
Thanks SOO much!
tbird2340
Copper - Posts: 363
Posted: June 25, 2008 at 10:12 AM / IP Logged
just checking if you had a chance to write the how to. thanks.
