which speakers?
twobig86
Copper - Posts: 84
Posted: June 21, 2008 at 5:00 PM / IP Logged
I work with bestbuy and I have been getting some employee purchase plans from different car audio companies.  Alpine had one last month however I got my order in too late.  We should be getting another one from Alpine soon.  However the best 6 1/2 components were the SPR-17s.  I have just recieved one from JBL (need to place the order soon however...hence the asap in the title.) and they are giving us a much better deal (looking at the discount anyways) than Alpine was.  However I need help deciding.  I know what im leaning towards however I would like some input from some of you first.
Following is a list of each set of speakers that im looking at.  Followed by a quick spec sheet as well as the website from the manufacturer. After that the price per set (2 speakers per set, Im looking for 4 of them)
Please let me know your opinions.  Ive never had speakers from either company so I have no experience with their products.  Ill say right now that im not looking to buy the $500.00 competition ones though I would like to know what people think of them and the price as well.
Alpine
SPR-17S
SPECIFICATIONS
General
• Sensitivity: 87dB / W(1m)
• Impedence: 4 Ohms
• Frequency Response: 65Hz - 27kHz
Dimensions
• Crossover Size (in): 4-9/16'' x 2-7/8'' x 1-1/4''
• Crossover Size (mm): 115.4mm x 73mm x 32mm
• Woofer Mounting Depth (in): 2-5/16''
• Woofer Mounting Depth (mm): 59mm
• Woofer Mounting Diameter (in): 5-11/32''
• Woofer Mounting Diameter (mm): 136mm
• Woofer Diameter (in): 6-1/2''
• Woofer Diameter (mm): 165.1mm
• Tweeter Mounting Depth (in): 18.3mm
• Tweeter Mounting Depth (mm): 3/4''
• Tweeter Mounting Diameter (in): 2''
• Tweeter Mounting Diameter (mm): 51mm
Power Handling
• Power Handling Capacity (Peak): 330 Watts
• Power Handling Capacity (RMS): 110 Watts
• CEA-2031 Power Rating: 110 Watts
http://www.alpine-usa.com/US-en/products/product.php?model=SPR-17S&lang=en&tab=F
$136.00 (SPR-17S)
JBL
Component Systems
Power Series
P660C
SPECIFICATIONS
Warranty One YEar
General
Power Handling, RMS 90 Watts
Power Handling, Peak 270 Watts
Sensitivity 94dB
Frequency Response (±3dB) 45Hz - 23kHz
Mounting Depth Mid/Woofer 2-1/4" Tweeter 1-3/16"
Impedance 2 Ohms
http://www.jbl.com/car/products/product_detail.aspx?prod=P660C&Language=ENG&Country=US&Region=USA&cat=COS&ser=POS
$100.00 (P660C)
Component Systems
GTi Series
C608GTI MKII
SPECIFICATIONS
General
Power Handling, RMS 150 Watts
Power Handling, Peak 600 Watts
Frequency Response (±3dB) 50Hz - 21kHz
Sensitivity (2.83V @ 1m) 89dB
Impedance 4 Ohms
Crossover Frequency(ies) 3.5kHz, 24dB/oct
Mounting Depth 2-11/16" Woofer, 1-1/8" Tweeter
http://www.jbl.com/car/products/product_detail.aspx?prod=C608GTI%20MKII&Language=ENG&Country=US&Region=USA&cat=COS&ser=GTI
$162.50 (C608GTI MKII)
Component Systems
GTi Series
660GTI
SPECIFICATIONS
 General
Frequency Response (±3dB) 50Hz - 30kHz
Sensitivity (2.83V @ 1m) 91dB
Impedance 4 Ohms
Mounting Depth 3-1/16" Woofer, 1-5/16" Tweeter
http://www.jbl.com/car/products/product_detail.aspx?prod=660GTI&Language=ENG&Country=GB&Region=EUROPE&cat=COS&ser=GTI
$500.00 (660GTI)
Amplifiers
Grand Touring Series
GTO1004
SPECIFICATIONS
Warranty One Year
General
Power Output 100W RMS x 4 Channels at 4 Ohms 150W RMS x 4 Channels at 2 Ohms
Signal-to-Noise (dBA) 104dBA (reference rated power into 4 ohms)
THD 0.02% (rated power at 4 ohms)
Frequency Response 10Hz - 100kHz (-3dB)
Dimensions (L x W x H) 18-9/16" x 10-3/8" x 2-1/8"
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO1004&Language=ENG&Country=GB&Region=EUROPE&cat=AMP&ser=GTS
$170.63 (GTO1004)
Amplifiers
Power Series
PX300.4
SPECIFICATIONS
General
Power Output 123,5W x 4 into 4 ohms
169W x 4 into 2 ohms
358W x 2 into 4 ohms, bridged
Max Power 600W Peak x 2
Signal-to-Noise Ratio >95dB
Total Harmonic Distortion 0.04%
Frequency Response 10Hz - 45kHz ±1dB
  Built-in variable electronic crossover with selectable slope
  Dynamic Bass Optimization™ (DBO) circuit
  Preamp outputs
  Differential inputs
  Internal-lighting-ready
  Direct-Connect
Dimensions (H x W x D) 312mm x 432mm x 66mm
http://www.jbl.com/car/products/product_detail.aspx?prod=PX300.4/230&Language=ENG&Country=GB&Region=EUROPE&cat=AMP&ser=POS
$261.00 (PX300.4)
Those are the 2 best 4 channels I can get on discount.
Thanks in advance for everyone who posts. =)
twobig86
Copper - Posts: 84
Posted: June 21, 2008 at 5:01 PM / IP Logged
P.S. I have a 300 amp Iraggi alternator and two optima red tops powering my system.  2 - 1000 watt MTX amps for my 2 MTX subs.
twobig86
Copper - Posts: 84
Posted: June 21, 2008 at 5:15 PM / IP Logged
I should also mention that I like loud music and like to show off my system.  Like to listen to all sorts of music but mainly hip hop style music.
fiberglasslvr
Copper - Posts: 116
Posted: June 29, 2008 at 3:36 PM / IP Logged
in my opinion i would probably go with the C608GTI MKII  ive used them before and they sound amazing i think they have a much better tone than the type r comps.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
