car head unit and amp in home
mp2031
Member - Posts: 7
Posted: July 23, 2008 at 7:25 PM / IP Logged
has anyone here done this kind of thing ? , as i would like to get a more suitable power supply for this maybe something that can put out around 1000w with no trouble
Miles
advanced_audio
Copper - Posts: 170
Posted: July 23, 2008 at 7:29 PM / IP Logged
Is it fused? If so what size fuses are in there?
haemphyst
Platinum - Posts: 5,054
Posted: July 24, 2008 at 10:28 PM / IP Logged
If you want to run 1000 watts of amplifier power, then you need 2000 watts of power supply. While that is not a hard and fast number, it is a good rule of thumb.
2000\13.8=145A
That's a HUGE power supply. I have a 100A power supply in my garage, and it is welded to a 4 wheeled cart. It weighs somewhere in the vicinity of 175 pounds!
mp2031
Member - Posts: 7
Posted: July 24, 2008 at 10:43 PM / IP Logged
oh yeah i see , can i use 2x13.8v1000w power supplys ? or will this not work ?
haemphyst
Posted: July 24, 2008 at 11:43 PM / IP Logged
Analog (meaning big, heavy) power supplies don't care about their outputs being paralleled. No issues with doing that.
Switch-mode power supplies... Ummm... not so much. Before you try to parallel those, check to be ABSOLUTELY CERTAIN it can be done.
mp2031
Member - Posts: 7
Posted: July 25, 2008 at 7:19 PM / IP Logged
ok , im getting a tailor made power supply @ 2000w 13.8 v Dc 145 amps ,
i will let you know how it goes .
car head unit and amp in home - Page 2 -- posted image.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
