2006 Lincoln Navigator Stereo/Alarm Wiring
hoppin62
Member - Posts: 10
Posted: August 16, 2008 at 11:25 PM / IP Logged
Does anyone have a diagram for my 2006 Navigator? I have factory navigation, flip down tv/dvd player, premiun sound with amplifier. I tried to install my Kenwwod unit with a harness I had from my 2004 Navigator, but it only powered on he Kenwood, but no sound!Any help would be appreciated.
Thanks!
Platinum - Posts: 13,667
Posted: August 16, 2008 at 11:38 PM / IP Logged
Was there a power antenna wire on the harness that plugged into the vehicle harness? If so did you connect it to the amp remote wire of the Deck?
hoppin62
Member - Posts: 10
Posted: August 17, 2008 at 1:01 AM / IP Logged
Yes I did, but I just noticed that where I have my 4 wires that are speaker outputs on my harness from the deck.... those pins on the harness from the dash are empty! Maybe I need more than one harness from my deck to the dash! My factory radio has 4 harnesses (1 big one and 4 smaller ones) I'm confused!
Posted: August 17, 2008 at 5:43 AM / IP Logged
Does one of the now empty harnesses have 8 pins on it?  If so it appears as though it is the input plug for the premium sound amplifier.  There is a harness available to make those connections.  Metra 70-5521 is the number for said plug.   Good Luck and Happy Listening.
hoppin62
Member - Posts: 10
Posted: August 17, 2008 at 12:55 PM / IP Logged
I have 3 plugs from the dash that I am not using, the all have more than 8 pins... more like 16 - 20 in each! That's why the little smaller harness from Metra 70-5521 is throwing me off, because it will not fit! Maybe I need to cut the sides off of the smaller metra harness? I don't know. I received some diagrams, maybe I can just hard wire the unit.
Posted: August 17, 2008 at 2:32 PM / IP Logged
Can you take a picture of the back of the radio?
hoppin62
Member - Posts: 10
Posted: August 17, 2008 at 3:39 PM / IP Logged
I have hard wired the stereo now, I got everything to work with the factory amp except the subwoofer, that's what I am working on now!
hoppin62
Member - Posts: 10
Posted: August 17, 2008 at 3:42 PM / IP Logged
2006 Lincoln Navigator Stereo/Alarm Wiring -- posted image.
hoppin62
Member - Posts: 10
Posted: August 17, 2008 at 3:49 PM / IP Logged
This is what I meant by not having enough wires in the dash harness to have sound!
hoppin62
Member - Posts: 10
Posted: August 17, 2008 at 3:54 PM / IP Logged
This is where I found my 4 speaker inputs, sub input and factory amp turn-on! Currently, I don't beleive there is a aftermarket harness for this plug. (that's what they told me at a few stereo shops I went to!)
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
