2005 tacoma with jbl system
soundimpression
Posted: September 03, 2008 at 1:30 PM / IP Logged
Anyone know the impedance of the factory speakers? Trying to decide if an integration harness or wiring to the factory speakers is going to cost less. I need to bid this job right away.
Al
Sound Impressions, Inc.
Colorado Springs
megaman
Copper - Posts: 385
Posted: September 03, 2008 at 2:48 PM / IP Logged
3 ohm.  If the factory amplifier is directly behind the AC controls, you can bypass the amp and go direct with the standard harness.
soundimpression
Posted: September 03, 2008 at 9:10 PM / IP Logged
Thanks much for the info. that makes life easier.
Al
Colorado Springs
spookiestylez
Silver - Posts: 531
Posted: September 03, 2008 at 10:06 PM / IP Logged
you'll see the bolt for the factory amp right under the radio after its removed. After you take it out you can use the 70-1784 plug like normal.
rtfm
soundimpression
Posted: September 03, 2008 at 11:30 PM / IP Logged
Which manufacturer is that part number for? I can't find that pn in metra or scosche, or ai or from aamp.
Al
Colorado Springs
snotdobbs
Copper - Posts: 148
Posted: September 04, 2008 at 11:46 AM / IP Logged
i think he meant 70-1761 its a metra part number, 70-1784 is a vw harness , best kits(aamp) is bha-1761.  But metra lists an amplifier bypass harness, and in the instructions for that truck it says that the amp is in the back of the truck on the rear wall, passenger side. The metra amp bypass part number is 70-8117
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
