stereo problem
DYohn
Moderator - Posts: 10,741
Posted: September 05, 2008 at 11:07 AM / IP Logged
I see names like Legacy and Pyle.  Both flea-market brands, and both likely to fail.  I suggest if you check ALL your speaker wiring and it is OK, then you need to get your speakers and your head unit checked out by a professional (unless you know how to test them?)  If you don't have damaged or loose speaker wires, either a speaker has failed or the head unit has.  In either case, you have something defective in your system.
dscyth3
Member - Posts: 8
Posted: September 05, 2008 at 11:15 AM / IP Logged
Any place you would recommend taking it? IE / Pepboys,etc?
dscyth3
Member - Posts: 8
Posted: September 05, 2008 at 11:38 AM / IP Logged
I've been posting on another fourm and they made me realize that last night while driving home while the stereo issue was occuring, the headlights were dim. I've been told that there wasn't enough power to go around so the head unit was shutting off in defense. I was told to buy a HO alt. In order to charge the battery. Any other suggestions?
dscyth3
Member - Posts: 8
Posted: September 05, 2008 at 6:56 PM / IP Logged
Took the battery and alternator to autozone and had them tested. Turns out the alternator was bad. fixed.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
