2005 jeep liberty remote start
Welcome Guest :)
skidd76
Member -
Posted: September 11, 2008 at 11:30 AM / IP Logged
I need the wiring diagram to install a remote starter on a 2005 Jeep Liberty please or if the 2004 or 2006 is the same then please let me know!! Thanx for your time!!
Just the KIDD in me!!
kola7126
Copper -
Posted: September 12, 2008 at 11:24 AM / IP Logged
MODEL | YEAR(S) |
LIBERTY | 2005 -2007 |
KEY | T-HARNESS | IMMOBILIZER |
CHRY KEY-1 | N/A | CHRYSLER'S SENTRY ANTI-THEFT TRANSPONDER System, Requires 791 Bypass Module and Extra Ignition Key |
PART | COLOR | LOCATION |
12 VOLT CONSTANT | RED (+) (X2) | IGNITION SWITCH HARNESS |
STARTER | LIGHT BLUE/RED (+) | IGNITION SWITCH HARNESS |
STARTER 2 | N/A | |
IGNITION 1 | PINK/LIGHT GREEN (+) | IGNITION SWITCH HARNESS |
IGNITION 2 | N/A | |
IGNITION 3 | N/A | |
ACCESSORY /HEATER BLOWER 1 | PINK / YELLOW (+) | IGNITION SWITCH HARNESS |
ACCESSORY /HEATER BLOWER 2 | PINK / YELLOW (+) | IGNITION SWITCH HARNESS |
KEYSENSE | N/A | |
PARKING LIGHTS ( - ) | PINK/RED (-) See NOTE *1 | @ HEADLIGHT Switch or BCM, 22-PIN Plug Pin 5, See NOTE *4 |
PARKING LIGHTS ( + ) | DO NOT USE!!! | |
POWER LOCK | TAN/DARK BLUE (1-Wire Door Lock System) See NOTE *2 | @ BACK of FUSEBOX, TOP LEFT Plug, Pin 14 |
POWER UNLOCK | Same wire, See DIAGRAM | See DIAGRAMS |
DOOR TRIGGER | See NOTE *3 | @ BCM, See NOTE *4 |
DOMELIGHT SUPERVISION | BLACK/ WHITE (-) or YELLOW/LIGHT BLUE (-) Requires Part #775 Relay | @ BACK of FUSEBOX, TOP LEFT Plug, Pin 30 |
TRUNK RELEASE | LIGHT GREEN / WHITE (-) | @ BCM, 26-PIN PLUG, PIN 17, See NOTE *4 |
SLIDING POWER DOOR | N/A | |
HORN | DARK GREEN/ PURPLE (-) | @ HORN SWITCH |
TACH | Any wire NOT RED / ORANGE or PINK/GRAY | @ ANY FUEL-INJECTOR or IGNITION COIL |
WAIT TO START LIGHT | N/A | |
BRAKE | WHITE/ TAN (+) | @ SWITCH ABOVE BRAKE PEDAL |
FACTORY ALARM DISARM | DISARMS with FACTORY REMOTE ONLY!!! | |
ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER |
EXTRA INFORMATION |
NOTE *1 the PARKING LIGHTS require a (-)Negative thru a 910 Ohm Resistor and an extra Relay part #775, to connect, See DIAGRAM NOTE *2 to LOCK requires a (-)Negative thru a 1400 Ohm Resistor and UNLOCK requires a (-)Negative thru a 426 Ohm Resistor, some units will also require 2 extra relays part #775, to connect, See DIAGRAM NOTE *3 the DRIVERS DOOR is a TAN (-) in the GRAY 26-PIN plug, pin 4, the PASSENGER DOOR is a TAN/RED (-) in the GRAY 26-PIN plug, pin 5, the DRIVERS REAR DOOR is a TAN/ORANGE (-) in the GRAY 22-PIN plug, pin 3, the PASSENGER REAR DOOR (-) is a TAN / YELLOW (-) is a TAN / YELLOW (-) in the GRAY 26-PIN plug, pin 22. When connecting to an ALARM SYSTEM, use all 4 DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM NOTE *4 THE BCM (Body Control Module) IS ATTACHED TO THE LEFT OF THE FUSE BOX. |
Friday, May 3, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
