Unique Wiring Problem
Rixx
Posted: March 11, 2003 at 12:39 PM / IP Logged
Hi there, I have a new DVD sat nav unit from a 2002 HONDA CR-V. I want to install this into a 1994 Honda Prelude. The problem i have is that the harness that comes with the DVD SAT NAV UNIT has a blue/white wire and a green wire. I am assuming one of these wires is for the spped pulse??
There is also a plug/relay on the harness which has a RED / blk wire, a yellow/orange wire and a yellow/black wire. This is supposed to plug into the fuse box. I am assuming that these wires are for power,acc and illumination, but then there is also a thick WHITE/ red wire on the harness which is also supposed to plug into the fuse box.. which looks like it is for power.??
I am having trouble finding out what these are for. Also, i am having trouble with cutting the wires from my Honda prelude vehicle and matching them up to a honda CR-V colour equivelant on the adapter that i had purchased.
Can anyone help and if possible provide WIRING DIAGRAMS for a 2002 HONDA CR-V (UK) and 1994 Honda Prelude 2.2Si VTEC (JAP), please.
I would appreciate any help that can be goven at all. Thank You.
hitesh meghani
Posted: March 11, 2003 at 2:52 PM / IP Logged
try emailing info to www.dhelectronics.com
a guy by the name of kuki is very good with this stuff, he may also be able to get you the right cables for your car.
good luck
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
