which 10'' sub, .65 cu ft, jl audio 500/1?
carguy411
Silver - Posts: 683
Posted: September 14, 2008 at 10:44 PM / IP Logged
ok i have a 2008 trailblazer ss with the factory nave and bose system. i was going to put my system back in from my tahoe which was a jl w7 but i want to save my cargo space so im goin with this http://www.qlogicenclosures.com/c-529-ql-c1gte110-does-not-fit-ext-models-.aspx.
now im just not to sure what sub i should go with dont want anything to crazy just lookin for some tight bass to enhance the system . ill be using my jl audio 500/1 mono amp. i was looking at wither kicker,mtx or mostlikely fosgate
please let me know what you all think.
thanks
basketthis69
Member - Posts: 48
Posted: September 14, 2008 at 11:41 PM / IP Logged
any mid-level speaker is probably what you're looking for. even the "comp" series from kicker produces nice tight strong bass. there isn't alot of bad choices from kicker or fosgate.... just think mid-level. not cheapest, not most expensive. for fosgate, you probably want something comparable to a p2 series for example. but, it's been a while since i've messed with them so it may be called something else now.... either way, you get the idea. GL!!!
Installer for life.
carguy411
Silver - Posts: 683
Posted: September 15, 2008 at 10:18 AM / IP Logged
i was thinkin gsomething along the lines of these
what you think
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4486
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2234
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6110
uising my jlaudio 500/1 amp
carguy411
Silver - Posts: 683
Posted: September 16, 2008 at 10:56 AM / IP Logged
from the above subs or whatever you recomed is it better to run the amp at 4 ohms or 2 ohms. from what i understoood that i read somewhere the jl amp runs 500 watts from 1.5 -4 ohms, so it doesnt matter theload you put to it it still puts out 500watts?
carguy411
Silver - Posts: 683
Posted: September 17, 2008 at 9:58 AM / IP Logged
what do you think of these subs anyone ever use them http://www.subthump.com/daytonsubs.htm
megaman
Copper - Posts: 385
Posted: September 17, 2008 at 11:34 AM / IP Logged
JL Slash series amps such as your 500/1 run regulated inputs and outputs so yes, they put out the same amount of power with loads from 1.5 to 4 ohms.
aznboi3644
Gold - Posts: 2,600
Posted: September 17, 2008 at 12:13 PM / IP Logged
Dayton makes some high quality drivers
carguy411
Silver - Posts: 683
Posted: September 17, 2008 at 12:53 PM / IP Logged
ok thanks guys.
so you think im better with the fosgate or better with a dayton
frozenuts
Member - Posts: 36
Posted: September 17, 2008 at 4:37 PM / IP Logged
Sound is very subjective. Since none of us will ever be in your car, we really do not care what you put in it...as long as you are happy. I never have had a problem with Rockford subs, and I have never heard of anyone having a problem with dayton subs. If you can, listen to each, and pick your favorite.
all bad things come in moderation. do not shop at fry's. Get your own log in Omar.
carguy411
Silver - Posts: 683
Posted: September 18, 2008 at 1:38 AM / IP Logged
i know thats the damn problem with audio.lol
well i narrowed it down to these 2 subs. i would listen but noone in the area carries the dayton so thats y i need a little help or recomendation. either way they are going to be mounted in the subthump trailblazer sealed box and running off a jl 500/1 amp
would you slect one over the other
thanks
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4486 http://www.subthump.com/daytonsubs.htm
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
