ports, closer or farther?
snhtown
Copper - Posts: 178
Posted: September 19, 2008 at 6:11 PM / IP Logged
Where should i place my ports? im going to put them next to the speakers. should i place them closer to each other? on the inside? or farther? on the outside of the speakers? or does it even matter? Im using 2 L7's in a 3.0cf box.
aznboi3644
Gold - Posts: 2,600
Posted: September 19, 2008 at 9:29 PM / IP Logged
depends on the install...but it doesn't really matter...is this for a trunk vehicle or an open cabin??
Are the L7's you have 10s??
DYohn
Moderator - Posts: 10,741
Posted: September 20, 2008 at 10:30 AM / IP Logged
The ideal location for ports is generally on the same baffle as the drivers and at lease one po0rt diameter away from any surface.
megaman
Copper - Posts: 385
Posted: September 20, 2008 at 2:04 PM / IP Logged
If you're slot porting then make sure it's on the same baffle as the speakers as well.
snhtown
Copper - Posts: 178
Posted: September 22, 2008 at 1:12 PM / IP Logged
yea thats the plan
they are 12 l7's  they are going in a dodge magnum so it will be an open cabin. i did a little bit of modifiing and the chambers are now going to be 3.25 cf  my port is 14.5L X 13.25W X 3H
so i should place the ports at least 3 inches away from any surfaces/walls? including the speakers? this is the only thing i dont quiet understand yet.....
stevdart
Platinum - Posts: 5,816
Posted: September 22, 2008 at 10:25 PM / IP Logged
You can build your slot port along one side (e.g. the bottom) of the enclosure if building it with MDF walls.  Just make sure to leave several inches of free space at both open ends, inside and outside of the box.
megaman
Copper - Posts: 385
Posted: September 23, 2008 at 9:09 AM / IP Logged
I just realized that yesterday I built a box for my customer with the slot port on the side of the box.  NOT on the same baffle.  Heading not what I say.  Oh bad me. ;)
