4000 watt powerbass in protection
Platinum - Posts: 13,674
Posted: October 12, 2008 at 7:22 PM / IP Logged
Have you used a meter to verify that the amp is seeing a 1 ohm load?   That amp wired into a (.)25 ohm load will do exactly what you are saying it is doing.
big sexy lac
Copper - Posts: 153
Posted: October 12, 2008 at 7:56 PM / IP Logged
Will do tomorrow will post my findings, but the amp stays cool and I have them wired just like the diagram in the subwoofer wiring guide in this site, but I will whip out the meter because befor I put in the brutus I had an auto tek sm1 1000w and it did the same thing and I just thought the amp couldn't handle the 4 -10's.
well?
big sexy lac
Copper - Posts: 153
Posted: October 18, 2008 at 2:56 AM / IP Logged
After checking with my dmm I was getting good current to the amp, but I screwed up and had them wired at .5 ohms., its all good now
well?
Posted: October 18, 2008 at 6:35 AM / IP Logged
If you had it connected to 4 DVC 2Ohm drivers, it was at (.)25 Ohms. It was reading (.)5 because of the resistance of your meter leads. You dodged a bullet.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 20, 2008 at 6:57 PM / IP Logged
big sexy lac wrote:
I'm having a similar problem and I don't want start a new thread so here it is.
Well, you SHOULD start a new thread.... that is how it works....4000 watt powerbass in protection - Page 2 -- posted image.
big sexy lac
Copper - Posts: 153
Posted: October 20, 2008 at 8:10 PM / IP Logged
Sorry ktm, won't happen again!
well?
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
