07 subaru wiring info needed
trusdamanr
Copper - Posts: 116
Posted: October 01, 2008 at 6:16 PM / IP Logged
Looking for a wiring diagram for a 2007 Subaru WRX, please help
Platinum - Posts: 13,672
Posted: October 01, 2008 at 8:19 PM / IP Logged
For the entire vehicle?
trusdamanr
Copper - Posts: 116
Posted: October 02, 2008 at 11:53 AM / IP Logged
Just remote start and alarm info
Posted: October 02, 2008 at 1:15 PM / IP Logged
07 subaru wiring info needed -- posted image.BatteryWHITE(+)IGNITION SWITCH HARNESS
07 subaru wiring info needed -- posted image.Ignition 1GREEN(+)IGNITION SWITCH HARNESS
07 subaru wiring info needed -- posted image.Starter 1WHITE/ BLACK(+)IGNITION SWITCH HARNESS
07 subaru wiring info needed -- posted image.All Door TriggerBLUE(-)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
07 subaru wiring info needed -- posted image.Domelight SuperBLUE(-)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
07 subaru wiring info needed -- posted image.LF LatchBLUE/ORANGE(-)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
07 subaru wiring info needed -- posted image.RF LatchYELLOW(-)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
07 subaru wiring info needed -- posted image.LR LatchYELLOW(-)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
07 subaru wiring info needed -- posted image.RR LatchYELLOW(-)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
07 subaru wiring info needed -- posted image.Trunk TriggerYELLOW/RED(-)AT COURTESY LIGHT IN TRUNK
07 subaru wiring info needed -- posted image.Parking LightsVIOLET(+)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN
07 subaru wiring info needed -- posted image.Accessory 1YELLOW(+)IGNITION SWITCH HARNESS
07 subaru wiring info needed -- posted image.Key SenseWHITE/ RED(+)IGNITION SWITCH HARNESS
07 subaru wiring info needed -- posted image.TachometerBLUE(AC)AT IGNITION COIL HARNESS UNDER HOOD
07 subaru wiring info needed -- posted image.Crankshaft SensorGREEN(-)AT ECM CONTROL MODULE ABOVE PASSENGER KICKPANEL07 subaru wiring info needed -- posted image.
07 subaru wiring info needed -- posted image.Camshaft SensorBLACK(-)AT ECM CONTROL MODULE ABOVE PASSENGER KICKPANEL07 subaru wiring info needed -- posted image.
07 subaru wiring info needed -- posted image.Speed SenseGRAY / YELLOW(AC)AT ECM MODULE BEHIND PASSENGER SIDE OF DASH
07 subaru wiring info needed -- posted image.Parking LightsVIOLET(+)AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN07 subaru wiring info needed -- posted image.
07 subaru wiring info needed -- posted image.Brake LightsWHITE/ BLACK(+)AT SWITCH ABOVE BRAKE PEDAL
07 subaru wiring info needed -- posted image.Reverse LightsBROWN / YELLOW(+)IN HARNESS AT LIGHT HOUSING
07 subaru wiring info needed -- posted image.HornRED / GREEN(-)IGNITION SWITCH HARNESS
trusdamanr
Copper - Posts: 116
Posted: October 02, 2008 at 5:36 PM / IP Logged
Thanks....any chance of getting one with the door locks and factory arm/disarm on it??
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
