alarm on siren off
xavier213
Member - Posts: 15
Posted: October 17, 2008 at 11:47 PM / IP Logged
Hi
I am trying to keep my alarm on but turn my siren off with a momentary switch and then have it reset…. I need this because 1 if I had a on/off switch I would forget to turn it on 2 I need to turn it off at work… trains pass my car all day and the alarm goes off 3-4 times
Platinum - Posts: 13,674
Posted: October 18, 2008 at 12:48 AM / IP Logged
A momentary switch will only turn it off as long as you are holding the button down.
xavier213
Member - Posts: 15
Posted: October 18, 2008 at 9:43 AM / IP Logged
ok...... so any ideas on how i can do what i want to do
xavier213
Member - Posts: 15
Posted: October 18, 2008 at 10:27 AM / IP Logged
i was thinking of using a set up like thisalarm on siren off - Last Post -- posted image.
carguy411
Silver - Posts: 683
Posted: October 18, 2008 at 2:25 PM / IP Logged
what alarm u have some of them you can temp by pass the shocksensor so you wont have that problem.
if not y not just put a switch in line with the siren wire and switch it off when u leave and switch it back when u get in the car
xavier213
Member - Posts: 15
Posted: October 18, 2008 at 6:15 PM / IP Logged
dont know what alarm it is i will get you that info asap... yeah i will just put a switch inline but i know i will for get to turn it on and my alarm has autoarm and i am inside by time itr arms.... i know i am making things hard nowv but easy for me later on
dualsport
Silver - Posts: 983
Posted: October 23, 2008 at 12:20 AM / IP Logged
You probably won't want to use regular mechanical relays to do this because one of the positions will have to draw power while the car is parked.
If your alarm doesn't have provisions to temporarily turn off the shock sensing, you could do it with some electronics to toggle between the two modes. Should be pretty easy if you have some experience with that.
megaman
Copper - Posts: 385
Posted: October 23, 2008 at 8:38 AM / IP Logged
You will want to disable the shock sensor, not the siren.  The reason being, if you arm the system, even with the siren off, the train will set off the alarm, and your car will sit with the lights flashing.  The lights draw far more current than the siren, so essentially it could drain your battery.
xavier213
Member - Posts: 15
Posted: October 23, 2008 at 7:30 PM / IP Logged
Thanks for all you help
i think i am just going to use a switch
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
