kenwood kac 9104d wired to dvc 2 ohm subs
drewy1322
Member - Posts: 23
Posted: October 19, 2008 at 4:12 PM / IP Logged
I am upgrading my system to include a Kenwood KAC-9104D and two 12" Kicker CVR DVC 2-ohm subs. I do not understand why there are four speaker terminals when the amplifier is a mono class d. How do I wire these subs to the amp using 4 terminals?!?! I am stumped please help...Thanks!!
fiberglasslvr
Copper - Posts: 116
Posted: October 19, 2008 at 5:53 PM / IP Logged
to run your two 12's on this amp all you have to do is
1- wire each sub independently to one positive and one negative
or
2- you can paralell the subs and connect them to one of the positives and one of the negatives
in process of changing everything
DYohn
Moderator - Posts: 10,741
Posted: October 19, 2008 at 6:40 PM / IP Logged
Several mono amplifiers include two sets of output binding posts simply for convenience in wiring multiple speakers.  The amp only has one output and like described above, you may use either positive and either negative, or both.  It makes no difference.
Platinum - Posts: 13,674
Posted: October 19, 2008 at 7:16 PM / IP Logged
The important thing is that you wire the woofers themself correctly.  If you want to use all 4 terminals of the amp, you should wire each woofer as in the following diagram.  Connect one speaker to one set of terminals of the amp and connect the other speaker to the other set of terminals of the amp.
Option 2 (series) = 4 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
kenwood kac 9104d wired to dvc 2 ohm subs -- posted image.
If you want to use only one set of terminals you should wire both woofers as in the following diagram.
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
drewy1322
Member - Posts: 23
Posted: October 19, 2008 at 10:04 PM / IP Logged
That is great info, I really appreciate the feedback. Would I want to run the subs at a lower ohm to get more power? (2 ohm vs. 4 ohm load) Also if I want to only use one set of terminals on the amplifier should I run two wires from one terminal or one wire from one terminal and splice the speaker wire to the second subwoofer? It doesn't sound safe to splice a speaker wire....
Posted: October 20, 2008 at 6:26 AM / IP Logged
You can not run those subs together at 4 ohms.  Your 3 choices are  (.)5 ohm,  2 ohms or 8 ohms.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
