2008 Nissan Rouge Alarm/Remote Start Wiring
civickid1
Member - Posts: 7
Posted: October 19, 2008 at 9:12 PM / IP Logged
looking for wiring info for 08 rouge, for remote/alarm
please help me
Platinum - Posts: 13,670
Posted: October 19, 2008 at 9:25 PM / IP Logged
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.BatteryBLUE(+)IGNITION SWITCH HARNESS
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Accessory 1PINK(+)IGNITION SWITCH HARNESS
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Accessory 2BROWN(+)IGNITION SWITCH HARNESS
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Starter 1RED(+)IGNITION SWITCH HARNESS
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Anti-Theft TypeUNIVERSAL IMMOBILIZER
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Key SenseLIGHT GREEN(+)IGNITION SWITCH HARNESS
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.TachometerLT GREEN(+)AT IGNITION COIL
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Speed SenseYELLOW(AC)AT INSTRUMENT CLUSTER
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Parking LightsRED(+)IN HARNESS IN DRIVER KICKPANEL
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Brake LightsYELLOW(+)AT SWITCH ABOVE BRAKE PEDAL
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Reverse LightsGREEN(+)IN HARNESS IN DRIVER KICKPANEL TO REAR
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.HornGRAY(-)IN HARNESS AT STEERING COLUMN
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Domelight SuperRED(-)AT BCM MODULE BEHIND GLOVEBOX
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.LF LatchWHITE(-)AT BCM MODULE BEHIND GLOVEBOX
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.RF LatchPINK(-)AT BCM MODULE BEHIND GLOVEBOX
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.LR LatchGRAY(-)AT BCM MODULE BEHIND GLOVEBOX
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.RR LatchLIGHT GREEN(-)AT BCM MODULE BEHIND GLOVEBOX
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Trunk TriggerVIOLET(-)AT BCM MODULE BEHIND GLOVEBOX
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Hood TriggerWHITE(-)AT HOOD PIN SWITCH2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Alarm DisarmBLUE(-)IN HARNESS IN DRIVER KICKPANEL TO DOOR2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.
2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.Alarm ArmRED(-)IN HARNESS IN DRIVER KICKPANEL TO DOOR2008 Nissan Rouge Alarm/Remote Start Wiring - Last Post -- posted image.
civickid1
Member - Posts: 7
Posted: October 19, 2008 at 9:31 PM / IP Logged
Not you again.  Thanks bro
please help me
jamaicanluva
Posted: January 28, 2009 at 2:00 PM / IP Logged
MODEL       YEAR(S)
ROGUE       2008 -
PART       COLOR       LOCATION
12 VOLT CONSTANT       BLUE (+)       IGNITION SWITCH HARNESS
STARTER       RED (+)       IGNITION SWITCH HARNESS
STARTER 2       N/A       N/A
IGNITION 1       PINK (+)       IGNITION SWITCH HARNESS
IGNITION 2       N/A       N/A
IGNITION 3       N/A       N/A
ACCESSORY /HEATER BLOWER 1       PINK (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2       BROWN (+)       IGNITION SWITCH HARNESS
KEYSENSE       LIGHT GREEN (+)       IGNITION SWITCH HARNESS
PARKING LIGHTS ( - )       N/A       N/A
PARKING LIGHTS ( + )       RED (+)       LOW IN DRIVERS KICK PANEL
POWER LOCK       PINK (-)TYPE B       IN DRIVERS KICK PANEL
POWER UNLOCK       BROWN(-)TYPE B       IN DRIVERS KICK PANEL
DOOR TRIGGER       PINK TO WHITE (-)       AT BCM LOCATED BEHIND GLOVEBOX
DOMELIGHT SUPERVISION       RED (-)       AT BCM LOCATED BEHIND GLOVEBOX
TRUNK RELEASE       LIGHT GREEN TO GREEN (-)       AT BCM LOCATED BEHIND GLOVEBOX
SLIDING POWER DOOR       N/A       N/A
HORN       GRAY (-)       AT STEERING COLUMN HARNESS
TACH       NOT ORANGE       AT FUEL INJECTOR
WAIT TO START LIGHT       N/A       N/A
BRAKE       YELLOW (+)       AT SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM       BLUE (-)       IN DRIVERS KICK PANEL
ANTI-THEFT       TRANSPONDER ANTI-THEFT       TRANSPONDER @ IGNITION SWITCH TUMBLER
Mark Mizenko
Copper - Posts: 460
Posted: January 28, 2009 at 2:51 PM / IP Logged
You dont need the 2Nd Acc for this vehicle.  And you can get the Pk Lights and Brake in the kick, in a big white plug.  Both wires are red.
If it has a regular key, you can get the starter wire inside.  If it's Intelligent key, you  need to go out to the IPDM for the starter wire (using a data bypass).
If you want/have to interrupt the security light on the cluster,  It's a Black wire at the back of the cluster, the are a few Blacks, in pairs.  The wire you want is the Back by its'self.
Posted: January 28, 2009 at 7:40 PM / IP Logged
I think the "Please Help Me" is his signature line.
ckeeler
Gold - Posts: 1,461
Posted: January 28, 2009 at 7:51 PM / IP Logged
what does that mean?
weird. whats going on IAAI? this guy doesnt want your help, and the other guy with the current draw cant see your posts. man theres been some funny threads lately.
hey civickid, its just a screen name, its sarcasm.
Posted: January 29, 2009 at 5:57 AM / IP Logged
I had helped him on an install in a jeep only a few weeks before.  He was not being sarcastic, I guess that he was just shocked that once again I had helpful info.
northern
Copper - Posts: 154
Posted: January 29, 2009 at 10:41 AM / IP Logged
WHAT kit are you guys using for vehicles with a smart key? XK07? DLPK? Whats best?
northern
Copper - Posts: 154
Posted: January 29, 2009 at 10:46 AM / IP Logged
Also anyone have any issue with the key cylinder locking up after 45 seconds if they have a smart key
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
