2008 honda pilot bypass
Memphisman
Copper - Posts: 161
Posted: October 21, 2008 at 7:35 PM / IP Logged
I just installed a RS in a 2008 Honda Pilot using the HONDA-SL3 bypass and I have a small problem. Everything works perfect except that when I start the car using the RS, the anti-theft light will keep blinking. It will still blink even after I insert the key into the ignition, turn it to run, and hit the brake so as to turn off the RS. Otherwise everything is normal. Any suggestions?
Mike M2
Platinum - Posts: 2,652
Posted: October 22, 2008 at 6:29 AM / IP Logged
Does it go out after you hit the brake?
Mike M2
Tech Manager
CS Dealer Services
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
