Help! 2003 Chrysler Sebring
midwayelec
Copper - Posts: 52
Posted: March 14, 2003 at 7:24 AM / IP Logged
I'm installing a remote start in a 2003 Chrysler Sebring, and need the wiring diagram ASAP. The company I work for had a contract with Wire Magic that ended yesterday, therefore I can't use it anymore. PLEASE somebody have this information so I can do my job...
Sean Cawby
Midway Electronics
Rensselaer, IN
219-866-3716
Moderator - Posts: 12,488
Posted: March 14, 2003 at 4:22 PM / IP Logged
Email me and I'll send you a file for this vehicle. Please let me know if it's a coupe, sedan or a convertible in your reply.
midwayelec
Copper - Posts: 52
Posted: March 19, 2003 at 4:28 PM / IP Logged
After installing the remote start, I had a problem with the door locks. The unlock worked, but both with the lock and unlock buttons on the remote. After going in and testing some things with my DMM, I found no solution. I tried to reset the remote start system by turning the key to the positions ON-OFF-ON-OFF-ON just as the remote start manual states. I continued the process and nothing worked. Now the car will not even start with the key. It does not have the Sentry-Key system. Also the radio does not turn on. Do you have any idea what would cause this? Any help would be greatly appreciated. Thanks,
Sean Cawby
Midway Electronics
Rensselaer, IN
219-866-3716
Posted: March 19, 2003 at 7:11 PM / IP Logged
Did you cut the starter wire ? Check all fuses inline of the RS and also on the car.
mobileinstallat
Copper - Posts: 92
Posted: April 11, 2003 at 12:15 PM / IP Logged
Jeff,
Send me a copy, mine is a sedan, 2003- with any of your short cuts or tips/your notes please. I know you improve the basic instructions and correct them, as only a guru can!
Thanks as always Jeff,
Mark
mobileinstallations@yahoo.com
Posted: April 12, 2003 at 12:09 PM / IP Logged
Hey Marc.....done !!
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
