astrostart model boa?
brhaugen
Copper - Posts: 275
Posted: November 21, 2008 at 6:24 AM / IP Logged
Hey all you Astrostart Gurus..
Need a little help.
Trying to find a replacement remote for a customer.
I looked at the back side of his unit and it is an Astrostart but has the model number of BOA.
I did a search for 'BOA' on Astro's website and it came up with the RSS-2504A. \
Is this correct?
Can I order a 2504-TX remote for him?
Thank you Much!
Brent Haugen
Fargo, ND
brhaugen
Copper - Posts: 275
Posted: November 23, 2008 at 8:34 AM / IP Logged
bump
anything?
please?
Brent Haugen
Fargo, ND
shaip99
Copper - Posts: 112
Posted: November 26, 2008 at 8:08 PM / IP Logged
yes that is the right model for that car starter its a black oval remote with four silver buttons
to program it open the hood make sure the hood pin is grounding properly
then go into the car turn the ignition on and press the brakes turn the ignition of and on three times
the park lights will flash twice then press any button the the remote fob the park lights will flash once that it has accepted it
press the brakes to confirm and exit programming and tada it should work
or if you can get to the brain flip dip switch 8 to the on position press the brakes then press any button on the remote press the brakes again and it should work
either way will do the same thing
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 27, 2008 at 3:02 AM / IP Logged
Programming the replacement transmitter can be done A LOT easier.
Find the brain, put dip#8 up, hit the brake pedal, push the unlock button on the NEW and OLD transmitter, put the #8 dip
down, hit the brake............done!
shaip99
Copper - Posts: 112
Posted: November 27, 2008 at 8:56 AM / IP Logged
did you actually read my entire post
KarTuneMan
Posted: November 27, 2008 at 3:07 PM / IP Logged
I guess I didn't......astrostart model boa? -- posted image.
brhaugen
Copper - Posts: 275
Posted: November 29, 2008 at 8:11 AM / IP Logged
Great!
So it is the same as the 2504 or the 2524.
Can I program either the one way or the two way remote to this starter?
Thanks,
Brent
Brent Haugen
Fargo, ND
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
