98 camry parking light wire?
snake07
Copper - Posts: 79
Posted: November 30, 2008 at 10:04 PM / IP Logged
Hi all,
I'm installing the remote starter for my 98 toyota camry and I can't find the wire for parking light.
The wiring guide said the parking light wire is Green located in the bottom left of the fuse panel, I can't find any green wire in the fuse panel as the wiring guide said.
Please be advice where to locate the parking light wire
98 camry parking light wire? -- posted image.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 01, 2008 at 7:51 AM / IP Logged
That IS the correct plug..... 3rd pin on the bottm row from the right!
Is your clip puncturing the wire? the green next to the red.... I can see it in your pic.
snake07
Copper - Posts: 79
Posted: December 01, 2008 at 9:00 AM / IP Logged
Thank you for your respond,
The wire at the clip was my initial spot for parking wire since I test with a meter and it's hot when I applied the brake but later on I found out that was not the parking light wire and it was the brake switch wire ( GREEN / WHITE) instead.
By the way, anybody know what's the black device (with arrow pointing and it's below the 7.5A panel fuse ) ? i believe it's a fuse and I blown it while I was testing for a parking light wire.
soundnsecurity
Gold - Posts: 2,711
Posted: December 01, 2008 at 1:55 PM / IP Logged
looks like a relay of some kind.
ckeeler
Gold - Posts: 1,461
Posted: December 01, 2008 at 2:11 PM / IP Logged
it kinda looks like a factory diode. if you pull it out, how many terminals does it have? if only 2 do they show continunity thru them?
snake07
Copper - Posts: 79
Posted: December 01, 2008 at 4:15 PM / IP Logged
That's a 2 pin device and it's not showing continunity when I tested it. I lost power for tail lamp and instrument panel...
I went thru the eletrical digram and it was a fuse.  I have the device with me and I'll stop by the auto part store and see if they carry it, otherwise i'll stop by the dealership.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
