tach programming, no start
rfwave
Copper - Posts: 120
Posted: December 06, 2008 at 12:28 AM / IP Logged
autostart AS-2461-TW-FM into 92 eagle vista .
i've never experienced something happened like this one ;
when i was programmed tach and realized there was an error ,but i kept go on (followed procedure ) , i  started the car with key . the car wont crank , i only heard some ZZZZ...noises .( car starter in good condition ) .
is it possible that the RS can prevent the current flow to starter of the car ??? . ( no starter kill ) .
thank you .
rfwave
Copper - Posts: 120
Posted: December 06, 2008 at 10:11 PM / IP Logged
why ? this is a tough ? for me .
Platinum - Posts: 13,670
Posted: December 06, 2008 at 11:01 PM / IP Logged
Does the starter turn the engine over at all? When you connected the starter wire from the remote start unit, did you cut the car's starter wire, and it possibly came apart when you spliced it back together?
rfwave
Copper - Posts: 120
Posted: December 08, 2008 at 1:17 PM / IP Logged
no , engine didnt turn over at all , it sounds like a very weak battery , ( but it is a new batt ) .  at first i wanted to install starer kill , i did cut the stater wire , then i changed my mind and reconnected .
as you said it possibly came apart . i will double check it in a warmer days ,right now  its  too cold outside .
thanks " idiot " .
Posted: December 08, 2008 at 6:26 PM / IP Logged
Did you check the battery voltage while attempting to start?
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
