2008 honda fit remote start
tbird2340
Copper - Posts: 363
Posted: December 12, 2008 at 7:44 AM / IP Logged
I'm doing an 08 Honda Fit and have a few questions..
1. Does this car need the second accessory wire hooked up? I have Techweb saying no but Bulldog's diagram saying yes.
2. Factory alarm disarm.. A few of the diagrams say "test this wire while turning the Key in the Drivers Door Key Cylinder." How exactly do you test this? What is it supposed to test as?
3. I've searched and read that a few guys have had trouble finding the lock/unlock wires.. They are just in the kickpanel in a white connector?
4. Do I need to hook up the factory arm wire? One diagram has it, another does not.
5. How hard is this car to do? Are the wires relatively accessible? Thanks much!
tbird2340
Copper - Posts: 363
Posted: December 12, 2008 at 6:48 PM / IP Logged
No one knows the answers to any of these questions? I have the customer coming in tomorrow.
Thanks!
tedmond
Gold - Posts: 4,610
Posted: December 12, 2008 at 8:05 PM / IP Logged
Thats alot of questions to ask if you installing for a customer. Have you ever installed a remote start ?
The car has 2 accesory wires, just wire up both anyways, doesnt do anything but maybe turn on the radio.
IN HARNESS IN DRIVER KICKPANEL TO DOOR OR AT SECURITY CONTROL MODULE UNDER THE DRIVERS SIDE OF THE DASH
- you meter the WHITE - Disarm and WHITE/ Red -ARM. use your volt meter, connect red to 12v and black to the wire you want to test. with the key in the door cylinder, turn the key to unlock the doors. This wire will go to NEGATIVE (-) and the volt meter should say 11-12.4 v DC. it will tell you what wire is the proper disarm and arm wires.
Power Lock - WHITE/ GREEN
Power Unlock - WHITE/ BLUE
look for a harness that is leading from the kickpanel towards the door jamb. This is the harness that will contain the lock/unlock wires.
you should always hook up disarm and arm wires.
hondas are usaully the easier if not easiest cars to do for the professional installer.  all the wires are either in the Drivers Kick Panel, steering collumn and ignition harness. all these are easily accessable if you remove the metal knee kick. good luck !
just a tip, make you you use a DMM and TEST ALLLLLLL - EVERYSINGLE WIRE
ckeeler
Gold - Posts: 1,461
Posted: December 12, 2008 at 9:00 PM / IP Logged
you took the words right out of my mouth
tbird2340
Copper - Posts: 363
Posted: December 12, 2008 at 9:04 PM / IP Logged
Why? None of them are mission critical.. I've installed around 30.. I test every single wire and triple check with diagrams along with asking questions before I do it to try and make the install easier for myself..
Thanks for the info tedmond. I appreciate it.
tbird2340
Copper - Posts: 363
Posted: December 13, 2008 at 8:44 AM / IP Logged
Has anyone ever done one of these?? It looks like the dash / plastic / kick panel is all one piece across the whole car!!!
tbird2340
Copper - Posts: 363
Posted: December 13, 2008 at 2:42 PM / IP Logged
For anyone else..
Just remove the fuse box cover and then there are three screws you take out to remove the steering wheel cover which gives you access to everything you need..
