93 mazda mx6, stereo wiring?
dominoeflux
Posted: December 21, 2008 at 1:04 PM / IP Logged
i have a 93 mazda mx6 ls with a pioneer head unit that i install awhile ago. everything is connected correctly but there are a couple wires that i need to ask about. after i installed the head unit there were three wires left untouched the colors are: orange, brown, and lightgreen w/ white strip. the orange wire is the illumination for the head unit's lighting but my problem is the aftermarket harness that came with the head unit has no wire for the illumination wire, i was wondering what wire on the head unit can i splice into so my head unit can light up.
another problem i have is that my presets don't save everytime that i take the key out of the ignition. i know its probably the ground not connected right, i have the factory wiring diagram for the car and it shows the ground wire being a black wire but when i look at the factory harness i see no black wire for ground. only a not used brown and lightGREEN / WHITE wire. is it possible that one of these are the ground for the head unit?
Hornshockey
Silver - Posts: 520
Posted: December 21, 2008 at 7:02 PM / IP Logged
The brown wire is another illumination wire, the GREEN / WHITE wire is a power antenna wire.
If the harness for your head unit does not have an illumination or dimmer wire, then you should just insulate the ends of the orange and brown wires, you don't want those shorting out, you'll lose your dash lights.   If you have a power antenna on that car then the GREEN / WHITE wire should be connected to the blue or blue/white wire from the headunit.  If you don't have a power antenna, then do the same for that wire, insulate the end.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
dominoeflux
Posted: December 21, 2008 at 7:49 PM / IP Logged
after i finished installing the head unit that was the very first thing i did. i've decided to go to an electronics store and just purchase a harness that comes with the illumination wire and keep it grounded the way it is which is to the chassis. thanks for the advice.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
