factory remote work via 2 relays?
loneranger
Copper - Posts: 572
Posted: January 08, 2009 at 8:25 PM / IP Logged
Ah.. OK. Seems you have your bases covered. Let me re-read this thread entirely, again.
Is it possible that the minute amount of EMF generated on the remote wires, from the coil, are reeking havoc with the remote? If so, you'll need to use a transistorized circuit.
robertsc
Copper - Posts: 337
Posted: January 08, 2009 at 8:35 PM / IP Logged
its got to be an rf issue
i put the ion i did today back together
i just want to try and figure this out
so you figure putting a diode on 30 to 87?
loneranger
Copper - Posts: 572
Posted: January 08, 2009 at 11:14 PM / IP Logged
Maybe. I would recommend using a transistorized relay circuit. You can build it yourself for a few dollars. You should be able to find schematics for a 12V circuit, with some googling. However, we're not really sure that's the issue but, at this juncture everything points to it.
CutDog504
Silver - Posts: 637
Posted: January 09, 2009 at 10:56 PM / IP Logged
Why not just use the relays to trigger the white lock/unlock wire in the vehicle???
loneranger
Copper - Posts: 572
Posted: January 09, 2009 at 11:38 PM / IP Logged
He obviously has some mad-scientist scheme, he is concocting.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
robertsc
Copper - Posts: 337
Posted: January 10, 2009 at 12:02 PM / IP Logged
in order for me to retain the factory alarm
this is for vehicles that the alarm is controlled by factory remote only
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
