1100f and keysense, 2006 tribute
ragj1976
Member - Posts: 19
Posted: January 26, 2009 at 4:59 PM / IP Logged
Hello Folks, just got an 1100F for a remote start in a 2006 Tribute. I know I need a keysense to shut down the transponder when the actual key is in, but I am confused a bit.. The 1100F takes some RX and TX data signal wires, does that replace the "old style" Keysense? Or am I missing something.. IN other words, all I need on this 1100F is RX/TX/GND and Ignition? Or do I need to grab key sense also?
-Roger
Bnluis
Silver - Posts: 578
Posted: January 26, 2009 at 7:08 PM / IP Logged
no need to hook up key sense in this car , besides is data.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
chriswallace187
Gold - Posts: 1,661
Posted: January 26, 2009 at 10:42 PM / IP Logged
There have been reports of problems when using an RF bypass module on a Tribute/Escape(i.e. one that uses its own transponder or a vehicle key).
When the remote start is activated with a key in the ignition, the vehicle would read two separate transponder codes at the same time and either display a "service" light or go into some kind of protection mode where it wouldn't start for a while(I never personally experienced this so I can't identify the specific problem). The solution to this was a relay activated by the keysense wire that would interrupt the bypass when a key was in the ignition. This shouldn't be a problem with a data bypass, however.
C Renner's Auto Electronix
ragj1976
Member - Posts: 19
Posted: January 27, 2009 at 6:27 AM / IP Logged
I see.. Another question, with the DEI 1100F Is the GWR lead an output or a turn on for the 1100F.. Or does the 1100F turn on when it see's ignition? The directions are insanely vague.
-Roger
Bnluis
Silver - Posts: 578
Posted: January 27, 2009 at 7:33 AM / IP Logged
you need to connect the GWR wire to activate the 1100f,
Luis
Sound Waves
kgerry
Platinum - Posts: 3,455
Posted: January 27, 2009 at 12:41 PM / IP Logged
it is the - turn on input....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
