best way to connect subs to amp
playaslaya
Member - Posts: 8
Posted: February 07, 2009 at 3:51 PM / IP Logged
My recently purchased amp came with a 'remote gain control' ( it looks like a small volume knob that connects to the amp and can be mounted by the driver). As you can tell i'm not too familiar with this device.
Just how critical is this component to the amp setup?
Would the amp still function properly without it connected to the amp?
ragsports
Copper - Posts: 192
Posted: February 07, 2009 at 5:41 PM / IP Logged
The remote gain in not needed at all. You will be fine without it and your amp will function fine without it.
ttpayne
Member - Posts: 22
Posted: February 07, 2009 at 7:50 PM / IP Logged
i want to get the 08 4 ohm dvc alpine type x 12", is each coil 500w, or 1000w rms. i know the ratings are exaggerated but would a 1000w alpine pdx fully powr it?
legit o puss
ragsports
Copper - Posts: 192
Posted: February 10, 2009 at 11:06 AM / IP Logged
A 1000 watt pdx should be fine for that woofer. The PDX line is underated, and that amp will put out more than a 1000 watts. This woofer is 1000 watts RMS total. 500 per coil..
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
