electronic turn signal substitute?
angelars
Copper - Posts: 176
Posted: February 14, 2009 at 11:21 AM / IP Logged
Can you guys refresh my memory? Its been a while since I've bought anything like this. I'm looking for something that would be an electronic version of a turn signal relay. It needs to be adjustable so that I can set it to any time interval between 1 and 30 seconds. Like a turn signal it would be triggered, turn on, turn off, wait for how ever long you set it for, and then repeat the process. I'm sure DEI or PAC makes something like this. Can you direct me to part numbers? Thanks!
Chris Luongo
Platinum - Posts: 3,746
Posted: February 14, 2009 at 11:51 AM / IP Logged
Look around for the people who sell sequential turn signal kits for cars. Try sequentialturnsignals.com, but there are other sites too. They might be able to point you in the right direction.
Also, not to sure if they'll do what you want, but some part numbers to look at are: DEI 528T, and PAC TR-7.
angelars
Copper - Posts: 176
Posted: February 14, 2009 at 12:08 PM / IP Logged
Thanks Chris! Can you verify that the DEI 528T will pulse on/off repeatedly? It needs to go on, off, on, off...ect at a pre-set interval. Thanks.
KPierson
Platinum - Posts: 3,527
Posted: February 14, 2009 at 1:19 PM / IP Logged
What are you putting this all in?  Whatever it is it sounds like an interesting project.
Kevin Pierson
angelars
Copper - Posts: 176
Posted: February 14, 2009 at 1:26 PM / IP Logged
I am working on developing a system that vibrates the drivers seat when the radar detector goes off. Everything else is finished being developed, I just need a less mechanical way (than a relay and turn signal flasher) of pulsing the signal. I have several other projects in development too.
KPierson
Posted: February 14, 2009 at 1:40 PM / IP Logged
What kind of current will the vibrator pull?
Kevin Pierson
angelars
Copper - Posts: 176
Posted: February 14, 2009 at 1:57 PM / IP Logged
Very little. Typically less than 2 amps, but final testing won't be until 4-6 weeks as I haven't decided on what to use for the 'pulsing' of the power.
KPierson
Posted: February 14, 2009 at 4:27 PM / IP Logged
I have some circuit boards here that have two "single turn" adjustment pots and onboard 2A relays.  The boards are about 2" x 2".  It wouldn't take much code to turn the pots in to ON and OFF time controllers and use the onboard relay to output 12vdc.  What kind of output do you have from the radar detector?
Kevin Pierson
angelars
Copper - Posts: 176
Posted: February 14, 2009 at 5:44 PM / IP Logged
It's a negative trigger, but we could also tap off of the LED if needed.
Posted: February 15, 2009 at 10:30 AM / IP Logged
Do they sell Velleman kits in the US? Part no 100 I think will give you trigger on/off repeated.  Costs about $8 here.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
