subwoofers for dummies
93_civic
Member - Posts: 41
Posted: February 20, 2009 at 5:53 PM / IP Logged
you know how 0 gauge wire is bigger than 2 gauge wire, does that apply to ohms, like is 4ohms louder than 8ohms? i have a 12" sub that's dual 4ohm, 2ohm, or 8ohm capable and im trying to figure out whitch one would give me the deepest bass? im trying to avoide having to wire my sub 8ohm's, screw it in the box, test it, then pull it out of the box, and do the same for 4 ohm's. please help!
- thanks in advance! subwoofers for dummies -- posted image.
DYohn
Moderator - Posts: 10,741
Posted: February 20, 2009 at 6:25 PM / IP Logged
No, it's not as simple as that. It depends on what amplifier you are using. What's the amp?
93_civic
Member - Posts: 41
Posted: February 20, 2009 at 6:34 PM / IP Logged
its a pyramid PB1500 2ch amp. im looking at the manual for the amp right now and it says "MINIMUM SPEAKER IMPEDANCE 4 OHMS!" if you want it bridged, whitch i do.
Platinum - Posts: 13,674
Posted: February 20, 2009 at 7:20 PM / IP Logged
Run 2 sets of wires out of your box.  Then you will not have to remove the woofer from the box to change wiring configurations.  Your only choice is to run the speaker as an 8 ohm driver.
Option 2 (series) = 8 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
stevdart
Platinum - Posts: 5,816
Posted: February 20, 2009 at 10:37 PM / IP Logged
Your best bet is to continue shopping for an amplifier.  Get a mono amp and you can load it at 2 ohms.  But until then, cause I know that money can be tight, work on setting up this existing system as good as you can make it.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
