sub wiring
teddy812
Member - Posts: 21
Posted: March 18, 2009 at 7:31 PM / IP Logged
i have 3 jl 13w7 and rockford fosgate t4000x1 bd.
how do i wire those subs?
and how much cu/ft need? (each sub)
sub 1500w  dual 1.5 ohm
amp 4000 watts rms x 1 ohm
         3000 watts rms x 2 ohms
         2000 watts rms x 4 ohms
full throttle
Platinum - Posts: 13,672
Posted: March 18, 2009 at 7:49 PM / IP Logged
Wire the coils of each woofer in series.  Then parallel the 3 woofers at the amp for a 1 ohm load.  The diagram below shows 2 ohm voice coils for a 4 ohm load per woofer.  Your result will be 3 ohms per woofer.
Option 2 (series) = 4 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
sub wiring -- posted image.
Wire each of your 3 woofers in the above manner.  Connect the 3 positive wires to the positive terminal of the amp.  Connect the 3 negative wires to the negative terminal of the amp.
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
