4 channels amplifier for low budget
sublinux
Copper - Posts: 83
Posted: March 23, 2009 at 5:39 PM / IP Logged
What did you recommand to me for a 4 channels amplifier arround 200$ CAD MAX!! I can buy online too.
stevdart
Platinum - Posts: 5,816
Posted: March 23, 2009 at 6:29 PM / IP Logged
What do you intend to do with this 4 channel amp?
sublinux
Copper - Posts: 83
Posted: March 23, 2009 at 6:32 PM / IP Logged
To apmplify 4 speakers :P In a chevy Cavalier 98 with aftermarket speakers. But i got an unused 2 Channels amplifier.. so i was thinking to buy only a 2 channels amplifier (Less expensive) and both will amplify 2 speakers each.
stevdart
Posted: March 23, 2009 at 6:39 PM / IP Logged
To amplify 4 aftermarket speakers.  Well that's a ton of information.  Then if those speakers are so worthless they are not given names, I suggest you look into the Profile selection of fine amps.
sublinux
Copper - Posts: 83
Posted: March 23, 2009 at 6:50 PM / IP Logged
Front: 2x Pioneer TS-G4642R
Rear: 2x Nextar NSP690CT
Useless Amplifier : Pyle PLAD212
HU: Sony XPLOD CDX GT220
The one and the only RCA output on the HU is used for my sub. My plan is to use Line output converter for the front and rear.
stevdart
Posted: March 23, 2009 at 7:16 PM / IP Logged
Yep, get a Profile which should be easy enough to find in your budget.  Look for warranty protection.
Use a separate, brand name (like Peripheral) LOC...not the high level converter built into the amp.
But better, use the line level (one and only) RCA from the deck for both sub and the four speakers.  Amplifiers generally have a full range pass thru, so you should be able to run the RCA to the sub amp and pass the full range signal through to the four channel amp.  Set crossover settings on the amps, not the deck, which means run the deck output full range.
sublinux
Copper - Posts: 83
Posted: March 23, 2009 at 7:28 PM / IP Logged
And what do you think if i use a amplifier like the Pioneer GM-3300T or Clarion APX2120 with the PLAD212... It will cost me like only 80$
stevdart
Posted: March 23, 2009 at 10:07 PM / IP Logged
The field's pretty much wide open and most of what you get is manufactured at similar Chinese factories anyway.  Tell you what, you make a choice and install everything with great care to detail.  Use this site for additional info.  Then come back and tell us what you think about your choices.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
