2004 jetta deck problem
choff86.5
Member - Posts: 8
Posted: April 12, 2009 at 4:51 PM / IP Logged
replaced the deck in my 04 jetta... i used a replacement wiring harness i did not cut the existing one. now when you shut off the car you take the key out all the accessory power turns off.
problem is my new deck does not turn off lol. so anyone with this problem. any solutions? i dont really want to run wires throughout the car into the ignition switch hence why i bought the wiring harness.
any suggestions would help thanks
Platinum - Posts: 13,672
Posted: April 12, 2009 at 7:16 PM / IP Logged
There is a difference in the VW and the Mercedes harness.  Constant and switched wires are reversed.  Did you connect both the radio's red and yellow wires to the yellow wire of the harness?   Or maybe both to the red wire if they sold you a Mercedes Harness.
choff86.5
Member - Posts: 8
Posted: April 12, 2009 at 8:45 PM / IP Logged
i have a clarion dxy785usb... had 2 yellow wires i hooked that up to the yellow in the harness and red to the red in the harness... harness says its for the VW 02 and up.
popeye004
Copper - Posts: 97
Posted: August 08, 2009 at 6:27 PM / IP Logged
Hey Choff did you figure this out because I have the save car and I was thinking of put a deck in my car.
