dei 530t window module problems
Atl_monte
Copper - Posts: 90
Posted: April 12, 2009 at 7:23 PM / IP Logged
I've installed a DEI 530T window module along with a Viper 791XV on a 1984 Oldsmobile Cutlass but I'm experiencing a few problems with the windows. 1st problem is that the passenger window rolls down when I arm the alarm or use the remote start feature, the windows works great on the one-touch down feature but when going up stop every inch. Any suggestions?
Posted: April 13, 2009 at 1:06 AM / IP Logged
Yes at a guess you've got up and down the wrong way round on the passenger side,  adjust the DIP switches as it states in the instructions, also test your power and grounds, make sure that they are good.
OmarR
Copper - Posts: 162
Posted: April 13, 2009 at 4:12 AM / IP Logged
If your window is going down upon arm, you will have to reverse the wires. Reverse the 2 at the motor and reverse the 2 at the switch.
